Results 1 to 5 of 5
Thread: MT Ballast
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    MT Ballast
    Have fixture with multi tap ballast being fed from 120/208v panel. They want circuits swung over to a 277/480v panel. Would we have to change the wiring at the ballast to another input/tap on the ballast for the higher voltage? Thanks
  2. #2
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,158
    Yes.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Quote Originally Posted by jumper View Post
    Yes.
    Thanks,
  4. #4
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,795
    Some multi-voltage ballasts will automatically adapt to the applied voltage, but some are reported not to ever work again on a lower voltage after they have been placed on a higher voltage circuit.
    If there are physical taps or tap wires, then it should be able to be converted in either direction by rewiring the tap connection(s).
  5. #5
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Thanks. Someone told me that electronic ballast only have 2 leads so why or how could you rewire? Not necessary.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
