Results 1 to 2 of 2
Thread: Troubleshooting Heat Trace
  1. #1
    Join Date
    Nov 2017
    Sullivan, IL
    Posts
    3
    I am working on a heat trace circuit that is not working. I checked for continuity between the two conductors, and they have continuity. Is this because of the semi conductor, or is it possible there is a short in the wiring? The breaker is on and doesn't trip like there is a short, but the cable itself doesn't work. Any suggestions?
  2. #2
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,078
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
