Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 146
Thread: you're wrong. no you're stupid. well you're stupider so there.
  1. #41
    Join Date
    Sep 2008
    UK
    Posts
    11,908
    Quote Originally Posted by Sahib View Post
    One sue sign the transformer is not big enough is it won't allow the motor to run by dropping out contactors due to excessive voltage drop on starting. But OP has not reported any such happening. So reductio ad absurdum, the transformer is big enough.
    An 875kVA transformer isn't big enough for a 1,000 hp motor. If you were in the business of designing drive systems you would have no difficulty in understanding that.
    There is no ad absurdum about it.
  2. #42
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Quote Originally Posted by Besoeker View Post
    let's agree to disagree
    imho it is sufficient
    especially if the 840 was measured at the drive output, then motor load is only ~750 kva (90 kva for the filter/xfmr consumption) on a 875 kva xfmr
    need more info from the op
  3. #43
    Join Date
    Sep 2008
    UK
    Posts
    11,908
    Quote Originally Posted by Ingenieur View Post
    If it was, it wouldn't run over temp.
  4. #44
    Join Date
    Nov 2003
    Roanoke, VA.
    Posts
    4,558
    Quote Originally Posted by ggunn View Post
    What is reality?
    A concept
    Sometimes I don't know whether I'm the boxer or the bag.
  5. #45
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    it did not run over temp
    he said that is what he expected to see ('usually') but did not, but rather the output was clamped at 840 which surprised him (and imo impossible)
    that is why we need more info
    but on the surface, if measured at the drive out, the most convenient point, the xfmr only operated at 750 or 85%
  6. #46
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    4,644
    Wouldn't it depend on how much the motor was loaded? Perhaps the motor was oversized, or the calculated size was just over the next size down?
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  7. #47
    Join Date
    Sep 2008
    UK
    Posts
    11,908
    [QUOTE=Ingenieur;1872442]it did not run over temp]/QUOTE]
    I don't see how else you can interpret "usually it just runs over temp."
    Seems unambiguous to me.
  8. #48
    Join Date
    Sep 2008
    UK
    Posts
    11,908
    Quote Originally Posted by electrofelon View Post
    Quite right. Possibly a number of things. But if the transformer got too hot that's one problem right there.
  9. #49
    Join Date
    Nov 2007
    Posts
    868
    These things here got me confused. Why do other people here claim that the setup is okay when the OP mentioned "it failed"? Did I miss a lot?
  10. #50
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,666
    1HP = 746 watts.
    1,000 HP = 746,000 watts.
    that's not allowing for any losses whatsoever.
    no heat, transformer loss, zip.
    125% would be 932,500 watts.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
Posting Permissions
  • You may not post replies
  • You may not edit your posts
