Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Millwork Recept.
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    1,783
    Millwork Recept.
    When you guys install receptacles in furniture/millwork doyou make the cut out/opening? Thanks.
  2. #2
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,036
    Quote Originally Posted by mstrlucky74 View Post
    Generally, No, but the oscillating tools available now are making that a lot easier
    Tom
    TBLO
  3. #3
    Join Date
    Apr 2008
    SW Florida
    Posts
    537
    Rarely, because if it's wrong you just bought some very expensive firewood.
  4. #4
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,041
    Quote Originally Posted by cpinetree View Post
    This.
    The general "rule" is that we don't. In fact, I've refused to do it once, even when asked, because I wasn't 100% sure I'd get it right. Bring the carpenter back into the room.
    That said, I've successfully done it many times, also.
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,157
    Generally we do not cut them if the carpenter is on the job since it's his work.
    Rob
  6. #6
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,018
    Quote Originally Posted by infinity View Post
    "You touch it, you own it" is the general rule.
  7. #7
    Join Date
    Aug 2006
    Miami Fla.
    Posts
    7,402
    We don't make the initial cut but 9 times out of 10 we fix them with a multi tool.
  8. #8
    Join Date
    Jun 2003
    Posts
    9,036
    Quote Originally Posted by chris kennedy View Post
    Something like this? Job is still needing to be done. Up on Scenic Byway #2 or North of it.
    Tom
    TBLO
  9. #9
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,263
    Quote Originally Posted by ptonsparky View Post
    At same time someone is lucky the cut wasn't oversized.
    Anymore I often prefer they measure to center of cutout make a smaller then needed hole there and let me finish it out if they aren't going to make a good fit. Oscillating tools make it easier to have more precision if done that way.
    Outlet box in side of cabinet that is supported by "plaster ears"? If I don't cut the hole myself it has a good chance of being too big for the plaster ears to work.
  10. #10
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,018
    Quote Originally Posted by kwired View Post
    Have you ever tried a RotoZip for this kind of work?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
