Results 1 to 2 of 2
Thread: Transfer switch subpanel powerwall
  1. #1
    Join Date
    Jun 2017
    Winston Salem, NC
    Posts
    2
    What do you guys think of this? What if I moved my house hvac, dryer, and a few thing that draw the majority of power over to a subpanel. I would intercept that subpanel with an automatic transfer switch similar to what I use for standby generators. Except that I have a PV with power wall system hooked up to the typical line side of the switch and the "grid" side feeding the subpanel hooked up to the typical generator side. Would this work? When the PV system and powerwall can no longer provide enough for the air conditioning, the system would switch over to grid power. Do I use a typical gridtie inverter? I dont know, just an idea i had today.
    I think if this system were to work it wouldnt require permits, roof load calculations, or utility company interferance.
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,719
    Quote Originally Posted by Chasfshnfool View Post
    Getting a permit should be the first thing on the list.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
