User Tag List
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Low Voltage Exam Washington County Maryland - Failing
  1. #1
    Join Date
    Nov 2017
    Hagerstown, Md, USA
    Posts
    12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Any suggestions on prepping for the low voltage exam?
    Ive failed it 4 times already. I can not utilize the Index in time.. Is there any tricks to finding key words in questions to look up?
    I take it again Dec 8th and feel no more confident than before.
  2. #2
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    2,024
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Grapestew View Post
    Ive failed it 4 times already. I take it again Dec 8th and feel no more confident than before.
    I'm assuming you already have a test prep book and have read it.
    First, cancel your test appointment.
    Second, do practice questions without timing until you are getting almost all of them correct.
    Then, do timed practice tests until you can score a 90% or better.
    If you never get there, check out being a plumber.
    The key words are the most important words in the problem. Identifying those is a skill I don't know how to teach.
  3. #3
    Join Date
    Nov 2017
    Hagerstown, Md, USA
    Posts
    12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Test prep book
    Quote Originally Posted by Coppersmith View Post
    Which Prep book do you recommend for low voltage?
  4. #4
    Join Date
    Nov 2017
    Hagerstown, Md, USA
    Posts
    12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Im a network engineer and all we want to do is pull cat5/6e cable. Im surprised they require all this. Very little is beneficial to me and useless information ill never use. Ive taken multiple exams for certifications, and this code book exam is a pain in the rear. Glad I didn't become an electrician!
  5. #5
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,133
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    There is a big difference between the IT world and the real world. I see it every time I look at an IT persons work who "only wants to run some CAT5 or CAT6". Hopefully by the time you pass this test you won't be one of them.
    -Hal
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,142
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What topics are you having trouble with?
    I agree with others that many IT guys I have come across know how to make final connections and do the software type tasks really well, but have no clue how to run wiring through a building.
  7. #7
    Join Date
    Nov 2017
    Hagerstown, Md, USA
    Posts
    12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    I understand completely, I crossed over into IT and had the very same impression of them. A LOT are like that, although you shouldn't paint with such a wide brush. I went to school for electronics engineering and worked security for 12 years. We pulled every kind of cable you can think of for low voltage systems like fire/security alarms, access control, CCTV, Nurse call systems ,. I've performed Ariel runs, poll to poll, underground, from 18/2, 22/4, 22/8. RJ6-59/ etc,. Im no stranger to pulling the cabling. That said, I always worked under the company's licenses. I never once failed an inspection either, I know whats expected, I just need to speed up my navigating of the book.
    My main issue is locating code efficiently to beat the timer. It's hard finding the code for me. I know OHM's law and how to calculate formulas . I have just wasted money already and want to get the right study material so I can pull a freaking license when we land cabling jobs.
  8. #8
    Join Date
    Jun 2003
    Posts
    4,133
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Fair enough. What study materials do they recommend? From what you just said this shouldn't be so hard for you.
    -Hal
  9. #9
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,031
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is 06 Limited Energy?
    09 is Telecom but telecom electricians are not certified
    Do you have the PSI exam candidate document? It tells you how many questions from the appropriate articles. Its available at L&I electrical website or from PSI
    Have you looked at the scope of work in 296-46B section 920? You are tested on what you are allowed to do, not what you typically did as a trainee.
    Keep in mind 06 includes fire alarm...but maybe you knew that.
    Mike Holt has a low voltage text, get that and study 100-200 questions per week.
    Moderator-Washington State
    Ancora Imparo
  10. #10
    Join Date
    Nov 2017
    Hagerstown, Md, USA
    Posts
    12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hbiss View Post
    -Hal
    They directed to the Mike Holt website. Other than that nothing specific.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
