User Tag List
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
Thread: Ground Wire From Ground Rod
  1. #11
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,048
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electrofelon View Post
    The ground rod is not required per NEC (and is stupid) so i think you can do whatever you want with it, as long as its done per the plans.
    Quote Originally Posted by infinity View Post
    It's a waste because look at the size of that huge concrete electrode that's buried in the ground compared to the rod.
    I kind of disagree with you guys. Not in theory but in practice.
    The NEC is not a design manual, it is a set of minimum safety standards. These drawings are engineering specs of how they want the light pole installed.
    It may be a waste of money but that's not up to the electrician. The electrician must install according to job specs.
    The 95% of people that you can't trust give the other 5% a bad name.
  2. #12
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,961
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by growler View Post
    Efelon wrote to just do it to code and not specs/plans, Infinity made no reference as such, he and I only said it was prolly a waste.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #13
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,613
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I wasn't suggesting that they don't install as shown just that the rod won't do much.
    Rob
  4. #14
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I fully agree. If it is on the plans, you must install even if not required by NEC. My point was since it is not required by the NEC, there are no requirements beyond any instructions stated on the plans.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  5. #15
    Join Date
    Jul 2005
    Posts
    886
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Looks like this #6 ground wire is run without conduit. What type of insulation would be needed? Thanks.
    I always used copper solid...I also always used #4
  6. #16
    Join Date
    Jan 2009
    Posts
    15,961
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cdslotz View Post
    #4 to a rod? Why?
    Derek
  7. #17
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,613
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    #4 solid yuck.
    Rob
  8. #18
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,120
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jumper View Post
    #4 to a rod? Why?
    Same reasons to use PVC coated RMC and cadweld
  9. #19
    Join Date
    Jun 2004
    Posts
    5,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    #4 to a rod? Why?
    Remember the size of the gec depends in installation method, not just type of electrode. FwIW.
  10. #20
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,613
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    But why solid?
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
