Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Ground Wire From Ground Rod
  1. #21
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,252
    Quote Originally Posted by infinity View Post
    But why solid?
    IDK, isn't stranded usually a little higher cost?
  2. #22
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,036
    Quote Originally Posted by kwired View Post
    Probably, but working with #4 solid versus stranded (labor) trumps any additional wire cost.
    Rob
  3. #23
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,252
    I would think difference is fairly negligible on a light pole application.
  4. #24
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,036
    Probably, I won't use solid if larger than #12 unless it's a pool application or in a cable.
    Rob
  5. #25
    Join Date
    Oct 2015
    US
    Posts
    675
    That install in a common practice for NYC agencies.. they love to waste money
    Sent from my SM-G950U using Tapatalk
  6. #26
    Join Date
    Sep 2012
    NJ
    Posts
    2,239
    I was told it was for lightning protection?
  7. #27
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,765
    Quote Originally Posted by mstrlucky74 View Post
    It offers a a very Very limited, basically useless, amount of lightning protection against a strike.
    Any direct or close strike will likely blow the durn pole right off the base.
    The costs outweigh the chance that the rod would actually be any measurable benefit.
    In short, it's a myth, old wives tale, and pure baloney IMO.
    "Electricity is really just organized lightning." George Carlin
    Derek
  8. #28
    Join Date
    Sep 2012
    NJ
    Posts
    2,239
    Quote Originally Posted by jumper View Post
    Wait so the lightning protection is suppose to save the poor from damage?
  9. #29
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,252
    Assuming you meant pole there, the pole is typically taking on a lot of current in a direct strike whether there is a ground rod or not. The poor, maybe a homeless person sleeping at the base of the pole, also probably isn't very well protected either way.
    Some of us have labeled those that specify ground rods where they won't really do much as "dirt worshipers"
  10. #30
    Join Date
    Sep 2012
    NJ
    Posts
    2,239
    Sorry I did. So wouldn't the ground rod be helpful be helpful in the event of a lightning strike and someone standing near the pole.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
