User Tag List
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 36
Thread: Ground Wire From Ground Rod
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Looks like this #6 ground wire is run without conduit. What type of insulation would be needed? Thanks.
    Attached Images Attached Images
  2. #2
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    The ground rod is not required per NEC (and is stupid) so i think you can do whatever you want with it, as long as its done per the plans.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,613
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Since it can also be bare any insulation will do. If it's colored then not white or gray.
    Rob
  4. #4
    Join Date
    Jul 2003
    MA
    Posts
    2,141
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PVC coated RGS for the conduit?
    Tim
    Master Electrician
    New England
    Yesterday's Technology at Tomorrow's Prices
  5. #5
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,961
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tkb View Post
    And 3/4" x 10' rod. Someone wants to throw money away.
    "Electricity is really just organized lightning." George Carlin
    Derek
  6. #6
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    So you can run bare or thhn in direct contact with earth?
  7. #7
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jumper View Post
    Why exactly is it a waste?
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,613
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes.
    It's a waste because look at the size of that huge concrete electrode that's buried in the ground compared to the rod.
    Rob
  9. #9
    Join Date
    Feb 2005
    Milford, MA
    Posts
    1,667
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    A lot of good info has been posted on this over the years here. A quick search should dig some up.
    Formerly J Erickson as username.
  10. #10
    Join Date
    Jan 2009
    Posts
    15,961
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rod not needed, so no GEC either. Rob Roy pipe to pole lights, not normal. Rob Roy is $$$$. Add Calweld connection also.
    Derek
Posting Permissions
  • You may not post replies
  • You may not edit your posts
