User Tag List
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Thread: Pulling Wire
  1. #11
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,670
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I figure labor takes about 3x longer to install conduit overhead versus underground.
    Underground conduit goes from point a to point b as the crow flies generally, not always though. Overhead will usually have obstacles and need to follow building surfaces sometimes necessitating the use of pull boxes mid run.
    Come wire pull time, underground runs generally use less wire since they are usually straighter. That leads to faster pulls, because again, there are no extra pull boxes mid run that we need an extra person to watch or help feed wire into, etc.
    I do as much underground as possible on any given job.
    Running conduit overhead sometimes means running conduit at the tail end of the job when the construction schedule is even more compressed, I like having my underground finished at the start of the job before the job turns into a chinese fire drill.
  2. #12
    Join Date
    Sep 2012
    NJ
    Posts
    2,354
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Fulthrotl View Post
    pipes in a ditch need to be plumb an pretty where they enter and exit the slab.
    if you are pulling feeders, it's probably a little bit faster pulling into the ground.
    if you can set your spools up at the gear, the wire goes into the ground pretty
    effortlessly.
    the setups of spools tuggers and whatnot is where the labor is saved.
    a time honored tradition is that the electrician pulling the wire should be the
    one who ran the conduit. this way, if they were an idjit, it's a self inflicted wound
    trying to pull the wire.
    if you know what you are about, you can pull long feeders by yourself. it's not
    commonly done, but it's doable.
    longest i've ever pulled solo is 500 MCM aluminum simpull, underground, 700'.
    the trickiest deal is getting it started. i use maxxis tuggers to get the pulling head
    in the pipe, and then go to the other end, and use a targetcam to watch the pull
    while i'm pulling.
    http://www.targetcam.net/
    https://www.ebay.com/itm/MAXIS-TRIGG...-/181052348361
    off grid remote camera. 4 mile range. 6 hour battery life.
    can view up to six cameras at a time.
    the maxis triggers.... i won't pull wire without them.
    Very very helpful. Thanks
  3. #13
    Join Date
    Sep 2012
    NJ
    Posts
    2,354
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by controlled View Post
    Definitely faster underground. You wouldn't be on ladders or lifts.
    Your on ladders and lifts when pulling wire?
  4. #14
    Join Date
    Sep 2012
    NJ
    Posts
    2,354
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by growler View Post
    I don't know, most overhead pulls are indoor with no rain or snow or mud. Lubrication tends to work better if the conduit isn't full of water. You can see if conduit is damaged in any way.
    The only way I know if a pull will be easy is if I ran the conduit. If I'm going to be pulling the wire the pull will be easy.
    I've heard that but why does it make a difference whether or not you have the person who ran the conduit install the wire? Thanks
  5. #15
    Join Date
    Sep 2012
    NJ
    Posts
    2,354
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is this the proper to do This?
    https://youtu.be/sMA9ybAtpzo
  6. #16
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,937
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    The targetcam link is dead for me.
  7. #17
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,690
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    If the person who installs the conduit KNOWS he will be the person who pulls the wire, he tends to do a much better job installing the conduit so it's easier to pull.
  8. #18
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,950
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MAC702 View Post
    "Electricity is really just organized lightning." George Carlin
    Derek
  9. #19
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,862
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    cause some people are dipsnits, and poor mechanics, and will put in stuff in a
    way that takes three times as long to pull as it should. if it can be pulled at all.
    you ran it, you pull it. oh, there two LB's, one in a corner, back to back,
    in the middle of a 350' run of two inch? and one is an LR,'cause you didn't have an LB?
    so you pull 190', and then get to an LR, and then pull it out and figure 8 about 200'
    of it on the ground, and then pull it in, so it all fits in the LR? and it's got soap on
    it, 'cause the purchasing agent saved $11 by not buying simpull?
    you pull it. have fun.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  10. #20
    Join Date
    Apr 2016
    Tampa, Fl
    Posts
    141
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not for wire pulling. That's why I'm asking. Always been told there's a labor savings when installing conduit in a trench or on the floor as opposed to overhead which makes sense but never got info on wire pulls being different.
    The primary reason I run as much conduit under the slab is the total length of the up-coming wire pull.
    The drops from conduit installed from above are longer than the stub-ups out of the slab to a receptacle for example.
    I try to run as much as possible under the slab. No one cares if the PVC is running at angles, unlike exposed conduit runs.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
