User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: Conduit Bodies
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Conduit Bodies
    What exactly make a mogul different than another conduit body? Size? Thanks,
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,624
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes size typically they are longer.
    Rob
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    What are the parameters that deems a conduit body a mogul?
  4. #4
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,044
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    I believe a mogul meets the full distance required between entries. The typical LB fitting gets away with less due to the "smaller dimensions" clause if listed and marked by the manufacturer with size and quantity of conductors.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  5. #5
    Join Date
    Feb 2003
    Illinois
    Posts
    23,908
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electrofelon View Post
    Many of the moguls also do not meet the requirements of 314.28 and rely on the "smaller dimension" rule for larger conductors.
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
  6. #6
    Join Date
    Jun 2004
    Posts
    5,044
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by don_resqcapt19 View Post
    Ok. I have actually never used or even seen a mogul in the wild. Do they allow the max conductor fill for the raceway size, unlike a regular LB?
  7. #7
    Join Date
    Feb 2003
    Illinois
    Posts
    23,908
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Some do, but most don't.
    Don, Illinois
  8. #8
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,053
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I learn something new every day. I hope I'm not running out of storage space.
    The 95% of people that you can't trust give the other 5% a bad name.
  9. #9
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,196
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here's an example of an LB which would allow the same fill as a conduit due to the fact that when you remove the cover there is no "opposite wall".
    The one pictured is a NEC LB 6X by Appleton
    Carry a big wallet with you when purchasing
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  10. #10
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,196
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by growler View Post
    Folks tell me that's one of my problems. They call it the "full bucket syndrome".
    Take a 5 gal bucket, fill it, then add more water. The water you add just flows out of the bucket.
    Same thing happens to me as the Code changes. Sometimes I remember a '93 Code change as current
Posting Permissions
  • You may not post replies
  • You may not edit your posts
