Results 1 to 2 of 2
Thread: Sub-metering
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    1,798
    Sub-metering
    If you have a sub meter that comes part of a dist. board or panel there are CT's that come with or inside the board/panel that need to be wired, correct? Thanks.
  2. #2
    Join Date
    Dec 2017
    NJ
    Posts
    9
    They may be loose and need to be installed over the conductors or they may be built into the assembly so that they are permanently installed around a busbar that carries the current.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
