Results 1 to 3 of 3
Thread: Light fixture mounting
  1. #1
    Join Date
    Dec 2017
    springfield mo
    Posts
    1
    Is there a code that says that you need a 8/32 screw minimum size for mounting fixture, 50 pound rated box?
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    17,166
    Not exactly worded that way but, read 314.27(A)(1) and (2), the listing is the key.
    Roger
    Join Date
    Jun 2005
    Logan, Utah
    Posts
    8,201
    UL 514A for metallic outlet boxes and UL 514C for nonmetallic outlet boxes both require a minimum of 2 8-32 for supporting a ceiling mounted luminaire of up to 50 pounds.
    Chris
Posting Permissions
  • You may not post replies
  • You may not edit your posts
