Results 1 to 5 of 5
Thread: Twisted wire splice on alarm sensors? Is this okay?
  1. #1
    Join Date
    Jun 2014
    Los Angeles, CA
    Posts
    14
    A customer of mine had a local alarm co come in and do his sensor rough in recently. All of the splices from the connector pigtails to the home run wiring are just twisted and wrapped with electrical tape. Is this okay? I would expect some kind of mechanical joint, preferably a solder but at minimum a crimp. Am I wrong here? He payed a lot for the work, looks like something my teenager would have done.
    Thanks for any insight.
  2. #2
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    35,684
    If the switch is normally closed, you will still get an input change to the monitoring device should the splice fail which indicates something is happening in that circuit.
    Probably would be better overall workmanship to use a connecting device or solder but energy level in this circuit is low and simple twisting together like was done will work pretty well if there is no physical strain to pull the connection apart.
  3. #3
    Join Date
    Sep 2008
    UK
    Posts
    11,044
    Quote Originally Posted by whackit View Post
    I don't know if your code would permit it but, even if it does, I wouldn't do it that way. I'd use an electrical connecting strip. Chocolate blocks we call them.
    https://www.amazon.co.uk/Bulk-Hardwa...terminal+strip
  4. #4
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,777
    I use B caps or Beanies. they are filled with gel, look like a wire nut, but are crushed, Kliens can be used for this
    Moderator-Washington State
    Ancora Imparo
  5. #5
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,476
    Quote Originally Posted by tom baker View Post
    That's why alarm installers are called "Beanie Boys". They are about the only ones who use those things. Whenever you see them you can be sure it was the security guys.
    They don't look like a wire nut Tom, more like a Good and Plenty or a cigarette butt. And although they are designed with an insulation piercing inside so that the wires didn't need to be stripped, don't believe it. Always strip and twist first. These were first developed by the phone company for solid wire but they stopped using them because the insulation piercing was very unreliable.
    These are great for splicing solid to stranded.
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
