Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Storage Batteries
  1. #1
    Join Date
    Dec 2017
    oak forest illinois usa
    Posts
    1
    Storage Batteries
    article 480.6 is "overcurrent protection for "Prime movers"
    what is the definition of a "Prime mover"
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,332
    I believe it is any equipment that converts energy from another source
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    738
    In hybrid vehicles (including Diesel-electric locomotives), "prime mover" refers to the infernal-combustion engine, but the NEC doesn't apply to vehicles.
    It sounds like 480.6 refers to batteries whose only purpose is starting infernal-combustion engines and are not tied into a building's electrical system.
  4. #4
    Join Date
    Jul 2006
    Roughly 5346 miles from Earls Court
    Posts
    2,602
    Yep, "prime mover" refers to the engine/turbine turning an alternator/generator, or "the first thing that turns" in the system .
  5. #5
    Join Date
    Jun 2005
    Logan, Utah
    Posts
    8,201
    Quote Originally Posted by J Fimbianti View Post
    480.6 permits batteries that provide power for starting, ignition, or control of a prime mover (Generator) to not have overcurrent protection for the conductors between the batteries and the starting equipment of the generator.
    Chris
  6. #6
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,524
    Maybe I'm missing something but I don't see the words prime mover anywhere in 480.6.
    Ron
  7. #7
    Join Date
    Jun 2005
    Logan, Utah
    Posts
    8,201
    Quote Originally Posted by ron View Post
    Ron, I have pasted the 2017 NEC 480.6.
    480.6 Overcurrent Protection for Prime Movers. Overcurrent
    protection shall not be required for conductors from a battery
    with a voltage of 60 volts dc or less if the battery provides power
    for starting, ignition, or control of prime movers. Section 300.3
    shall not apply to these conductors.
    This was 480.5 in the 2014 NEC.
    Chris
  8. #8
    Join Date
    Feb 2003
    Posts
    4,524
    Quote Originally Posted by raider1 View Post
    Thanks Chris, I have to get with the times.......
    Ron
  9. #9
    Join Date
    Jun 2017
    WI, USA
    Posts
    363
    Quote Originally Posted by zbang View Post
    Agree.
    NFPA 37: Standard for the Installation and Use of Stationary Combustion Engines and Gas Turbines
    3.3.3  Engines. Prime movers such as internal combustion engines, external combustion engines, gas turbine engines, rotary engines, and free piston engines using either gaseous fuels or liquid fuels or combinations thereof.
  10. #10
    Join Date
    Feb 2013
    India
    Posts
    2,456
    Chris
    It is a bit surprising that the code does not require it. In one incident I saw melting and smoking of 12V battery leads PVC insulation due to some short in the starter motor of a 30KVA generator.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
