Results 1 to 5 of 5
Thread: Lextar
  1. #1
    Join Date
    Oct 2007
    Piedmont region of NC
    Posts
    731
    Lextar
    Hello,
    I am quoting a LED upgrade at a local veterinary hospital that has 2 x 4 troffers in it. One of my lighting suppliers has quoted me a
    Lithonia Epanl 24-40L-40K. I am always worried about driver and diode failure so I had him send me a picture of the driver that was in the light that he had in stock. (I do understand that manufacturers use several brands of drivers). The picture he showed me was of a
    Lextar TLI-034G032-D1 driver. Does anyone know whether or not this is a high quality driver? I googled Lextar and could only find fixtures that they build and not drivers. Is Lithonia making an elcheapo fixture for the mass market? Can all of their drivers and diodes be trusted?
    Thanks for the valuable help.
    Happy Holidays to you all....
    Ravenvalor
    Electrical Contractor
    Piedmont Region of NC
    "Good day and good premises." (Ayn Rand)
  2. #2
    Join Date
    Dec 2015
    Port Angeles, WA
    Posts
    82
    Quote Originally Posted by Ravenvalor View Post
    Hello,
    Not sure about the quality of the driver but I've installed a number of these with good success. https://www.platt.com/platt-electric...spx?zpid=93195
    Looks like Phillips uses their own drivers as well.
  3. #3
    Join Date
    Oct 2007
    Posts
    731
    Quote Originally Posted by MattS87 View Post
    I don't think you can go wrong with a Phillips or Sylvania.
    Ravenvalor
  4. #4
    Join Date
    Jun 2010
    Posts
    1,928
    is that a screen grille? cleaning ability needs to be considered if its going into patient area.
    If the existing lamps are special high color rendition lamps that provides correct skin/flesh/hair color, you need to match it. Take note of lamps in the fixtures and don't assume exam area is the same as rest.
    But if they aren't already, color critical lighting with 95 CRI and 80+ R9 would be a good idea for the exam room even though it might cost over $500/ea. Lesser if the area is upgraded to fluorescent lamp based system and specialized lamps.
  5. #5
    Join Date
    Oct 2007
    Posts
    731
    Quote Originally Posted by Electric-Light View Post
    The edge panel is easy to clean plus it is practically air tight.
    The CRI of the existing lamps are in the 80s (standard T8 fluorescent).
    My concern is that the lumens with the LEDs is signifigantly lower than the fluorescent troffers (4 - f32t8/841 lamps). My research on this topic has not got me completely convinced that it does not necessarily matter.
    Thanks for the help..
    Ravenvalor
Posting Permissions
  • You may not post replies
  • You may not edit your posts
