Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
Thread: Your DMM
  1. #51
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,821
    Quote Originally Posted by Besoeker View Post
    Does LoZ mean a low impedance tester?
    For some reason ~2.5kΩ refers to low impedance, and seems standard for eliminating measurements caused by Capacitive inductance
    Roger Ramjet NoFixNoPay
  2. #52
    Join Date
    Jul 2009
    Ware Shoals, South Carolina
    Posts
    1,221
    Yes, LoZ means low impedance. That seems to be the standard marking on the selector switch.
    It is not wise to use that mode on a circuit board, because you might be trying to read the voltage across a one meg resistor & the 2.5K ohm would present itself as a short circuit, damaging up stream components.
    By the way that was the voice of prudence, not experience speaking.
    Advise is a dangerous gift, even from the wise to the wise.
  3. #53
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,821
    Quote Originally Posted by SG-1 View Post
    ..2.5K ohm would present itself as a short circuit, damaging up stream components
    Excellente', that one less knuckle protruding from my knuckle head
  4. #54
    Join Date
    Jul 2009
    Posts
    1,221
    Fluke makes an adapter for meters that do not have built in LoZ
    Here is a link to the SV225 Manual.
    http://assets.fluke.com/manuals/sv225___iseng0000.pdf
    Only costs nearly as much as a meter.
  5. #55
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,660
    odd. that pricing strategy must have been a fluke.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  6. #56
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,518
    Quote Originally Posted by ramsy View Post
    I would not call it capacitive inductance. Capacitive coupling, for sure, and capacitive induction in a pinch, but never capacitive inductance!
  7. #57
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    23,347
    A low-wattage bulb will do the same thing.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  8. #58
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,030
    Quote Originally Posted by Fulthrotl View Post
    The pun-seeking missiles have been launched...
  9. #59
    Join Date
    Jul 2009
    Posts
    1,221
    Quote Originally Posted by LarryFine View Post
    Yes, but not as conveniently.
    Just more economically.
  10. #60
    Join Date
    Jul 2009
    Posts
    1,221
    Quote Originally Posted by GoldDigger View Post
    How about electro-static induction ?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
