Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Suspending Conduit vertically for camera pendants
  1. #11
    Join Date
    Nov 2017
    Whg. WV USA
    Posts
    14
    I have used that clamp and do not like it. It does not hold well I would prefer to bend a 90 at the top and use 2 pieces of strut and strut clamps. or use two of these.
    Last edited by Little Bill; 01-03-18 at 08:55 AM. Reason: Spelling and Image placement
  2. #12
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,961
    I have used a similar clamp with rigid conduit, worked just fine.
    Moderator-Washington State
    Ancora Imparo
  3. #13
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,897
    I think it's going to look like hell with no way to adjust whether the conduit is plumb. That's why the swivel is the way to go.
    Wasn't there a threaded eye to go on the end of a threaded conduit? Would be easier for low voltage like this. Just hang it from a hook and run your cable up and out of the eye.
    ETA- like this only not decorative or that price. http://www.mylampparts.com/Products/...__SL18196.aspx
    -Hal
  4. #14
    Join Date
    Dec 2015
    Yakima, WA
    Posts
    181
    Quote Originally Posted by hbiss View Post
    -Hal
    I think the OP is trying to accomplish hanging the conduit but doesn't want to thread/re-thread it after it's cut to length.
    The 90* clamps mentioned work ok, but I would hang a piece of strut and use strut straps
  5. #15
    Join Date
    Jun 2003
    Posts
    3,897
    Kinda a** backwards to cut and tread the pipe then try to figure out if that clamp is a good way to support it. Wouldn't of taken that much more to thread the top end also while he was setup for cutting/threading even if he didn't use it for support. Nice to screw a bushing onto.
    -Hal
  6. #16
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,218
    I don't follow. I was assuming the conduits have been cut with a saw, not a threading machine. Seems like trying to figure out a way to thread it later is a significant task.
  7. #17
    Join Date
    Jan 2014
    chicago, il, USA
    Posts
    404
    Quote Originally Posted by BastionSecurity View Post
    All cameras will be hanging above conveyor belts so nothing will have the ability to hit the pipe. I didn't want to use the swivel plate because that means I will have to re-thread 100 pieces that I cut to length. Has anyone here used the clamp I posted a picture of. Thanks
    How do you have an 18' rigid pipe without threads at either end?
    The world is round, you will get there no matter what path you take.
  8. #18
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,218
    Quote Originally Posted by rlundsrud View Post
    Wouldn't he have the threaded end at the camera, a coupling between a 10' factory piece and an 8' piece, and a cut end at the top?
    Also, there are 20' sticks of threaded RMC available.
  9. #19
    Join Date
    Dec 2015
    Yakima, WA
    Posts
    181
    Quote Originally Posted by MAC702 View Post
    That's what I picture as well.
  10. #20
    Join Date
    Jan 2014
    chicago, il, USA
    Posts
    404
    Then he could reverse it and put the threaded end at the top with the swivel and use a no thread coupling at the camera. It wouldn't weigh enough to require threads.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
