User Tag List
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Suspending Conduit vertically for camera pendants
  1. #1
    Join Date
    Jan 2018
    White Plains MD
    Posts
    3
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello,
    I need some help with what the code says for suspending a camera 18' from a beam with Rigid Conduit. I am attaching my mock-up camera mount but keep in mind the camera will have to suspend 18' down from the beam. I was planning on using the Edge type conduit beam clamp. Please advise.
    Click image for larger version.
ID:	19240Click image for larger version.
ID:	19241Click image for larger version.
  2. #2
    Join Date
    Jan 2014
    chicago, il, USA
    Posts
    424
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would recommend a swivel plate like this.
    Attached Images Attached Images
    The world is round, you will get there no matter what path you take.
  3. #3
    Join Date
    Sep 2014
    Nashville, TN
    Posts
    153
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by rlundsrud View Post
    Agree on the swivel plate, particularly if forklifts are in use. Won't eliminate forklift damage but will certainly reduce it.
  4. #4
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,335
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GrayHair View Post
    How does that help? The OP said that the cameras MUST hang down 18 feet. What does putting that swivel on the JB at the end of 18 feet of rigid buy you?
  5. #5
    Join Date
    Sep 2014
    Nashville, TN
    Posts
    153
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    Without the swivel, something has to bend, break or otherwise move out of position. With the swivel, it's often just the camera that gets trashed; a quicker repair. At least that was my experience.
  6. #6
    Join Date
    Feb 2007
    USA
    Posts
    5,808
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It buys you a flex point - 18' feet and a little touch by something and SNAP!
    Other than just hanging by chain or cable I think it is a much better deal . I'd check the max weight of the swivel though. Probably use AL conduit
  7. #7
    Join Date
    Apr 2007
    Berkeley, CA
    Posts
    1,796
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think the proposal is to put the swivel at the top end of the 18' of rigid, not the bottom end. The bottom end would buy you a very small amount of displacement; the top end buys you a lot.
    Cheers, Wayne
  8. #8
    Join Date
    Feb 2007
    USA
    Posts
    5,808
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sierrasparky View Post
    Quote Originally Posted by wwhitney View Post
    Cheers, Wayne
    Thanks, that is what I was suggesting also.
  9. #9
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,704
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think the proposal is to put the swivel at the top end of the 18' of rigid...
    Ditto. This thread was great. I didn't know those existed.
  10. #10
    Join Date
    Jan 2018
    White Plains MD
    Posts
    3
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    All cameras will be hanging above conveyor belts so nothing will have the ability to hit the pipe. I didn't want to use the swivel plate because that means I will have to re-thread 100 pieces that I cut to length. Has anyone here used the clamp I posted a picture of. Thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
