Results 1 to 10 of 10
Thread: T8 LED Direct Power Replacement Lamps
  1. #1
    Join Date
    Oct 2007
    Piedmont region of NC
    Posts
    731
    Does anyone know whether or not the 120v direct wire T8 LED lamps are good reliable products. Phillips makes them and I trust the brand but I am still concerned about the customer satisfaction and overall quality of this technology. I do not believe LED retrofit kits or LED replacement troffers are going to be bright enough for this application which is a veterinary hospital. It seems to be a little dim in all of the rooms now with 4 - 4' fluorescent lamps.
    Thanks for the help with this one.
    Ravenvalor
    Electrical Contractor
    Piedmont Region of NC
    "Good day and good premises." (Ayn Rand)
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,011
    I've had great luck with the edge lit trouffers and the led lamp replacements for making things brighter. Only time will tell about the lifespan, but they all come with one year warrantees.
    If Billy Idol or John Denver is on your play list go and reevaluate your life.
  3. #3
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,356
    I just did half of a Dental office, offices & exam rooms. I used line voltage tubes with 5K color and they love them.
    Doing the other half soon.
    If you aim at nothing, you will hit it every time!
  4. #4
    Join Date
    Oct 2007
    Posts
    731
    Quote Originally Posted by ActionDave View Post
    Good to hear Dave. Were those the 120-volt self ballasted lamps? Did you find the LED lamps to be brighter than the fluorescent lamps?
    Did you find the edge lit troffers to be brighter than the fluorescent lights? Were the old troffers 2 - lamp or 4 - lamp?
    Thank you for the valuable advice......
    Ravenvalor
  5. #5
    Join Date
    Oct 2007
    Posts
    731
    Quote Originally Posted by Little Bill View Post
    Did you replace the 4 - sockets also Bill? Were the new LED lamps brighter than the fluorescents?
    Thanks...
    Ravenvalor
  6. #6
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,356
    Quote Originally Posted by Ravenvalor View Post
    Thanks...
    Only replaced ones that were cracked/broken. As I said, the Dentist and workers loved them. Yes they were brighter.
  7. #7
    Join Date
    Oct 2017
    San Diego, CA
    Posts
    4
    I have used LED Tubes in several applications, the only complaint I have recieved is that they are too bright. A good rule of thumb is to take the current lumen rating of the fluorescent system and cut it in half for the LED system. Keep in mind fluorescent tubes waste a lot of their lumens bouncing off of reflectors, while LEDS direct all of their lumens down the the space where you want them.
  8. #8
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    21,980
    I recommend avoiding the type that allow the ballast to remain in the circuit.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Richmond, VA
  9. #9
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,356
    Quote Originally Posted by LarryFine View Post
    Same with me, I think that is one of the "pluses" for changing to LED. It's also a good selling point to let customers know there is one less thing to have to replace.
  10. #10
    Join Date
    Jan 2018
    Santa Rosa, CA, USA
    Posts
    7
    I am an LED specialist, and can say without a doubt the answer is yes, they are amazing. Many have the "magic driver" which allows for not needing to bypass the fluorescent ballast. There is a slight loss in the power factor however.
    BUT, in LED you get what you pay for so cheap is never worth it. Make sure you look for high CRI, and be sure the color temperature fits your specific desire. In the case of a hospital you probably want 4000k to 5000k.
    Best,
Posting Permissions
  • You may not post replies
  • You may not edit your posts
