User Tag List
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
Thread: Why we need permits and inspections
  1. #11
    Join Date
    Mar 2003
    Vermont
    Posts
    1,946
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Our states attorney general recently sent a questionnaire out to any license holder about such installs.
    Seems they've had the litigant radish fielding all the maintenance and home improvement contractors , none of whom are required to have any certification at all here.
    Because we are agricultural and tourist based economy , our laws are that anything goes on farms and single fam dwellings.
    This has resulted in a LOT of similar work shown in the OP, where the state is powerless, 'fly by nights' rule, and any bona fide tradesman in business is always caught in the middle.
    For example. No certification is required for an HI
    That's not to say they are ALL bad, we've anything from retired GC's to engineering level inspection companies , but one never knows what one will get.
    So an EC like myself gets a HI report, said report details the usual '2 wires under a breaker', and/or open junction box , while walking right on by the bigger $$$ items
    Six months later, after the buyer/seller dispute festers into pre-court drama , i'm getting calls from lawyers
    "Did you address the HI report at Mr & Mrs Pissedoff's?"
    "Who"?
    "Mr & Mrs Pissedoff's on trunkslammer road, Dec 7th, your invoice states what work was done by your company"
    " Oh, ahhh, yeah....."
    "Well we have a serious problem there, in that items F, G, H, and I went unaddressed and uniformed, resulting in the suit against the realtors"
    "Well what does that have to do with me, those items were not on the report!"
    "The report was forwarded by an uncertified, unlicensed and uninsured entity"
    " So.....?"
    " So you're the last entity in/out of Mr & Mrs Pissedoff's residence that possess these qualifiers"
    " So.....?"
    "Son, you need to understand liability rests upon those WITH credentials, not those W/O them"
    "Uhmmmm.....Eruhmmmm....."
    ~RJ~
  2. #12
    Join Date
    Feb 2003
    New Jersey
    Posts
    3,794
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by romex jockey View Post
    I could post 100's of similar debaucheries.
    I'm sure you could as could I but did you ever think about the thought process it took to do a job like this ? It took a lot more effort to cut a hole in the panel cover than it would have to cut out the sheetrock and have the wiring enter through the bottom of the cabinet. And I thought I was the king of "not thinking out of the box".
  3. #13
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,128
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I am surprised there is no bushing on the cutout...
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  4. #14
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,325
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by goldstar View Post
    There is a sheet of plywood surrounding the panel which does appear to be recessed in the wall. If you look at the very bottom of the picture where the plywood stops, it appears that the wall is concrete or cinder block. It might not have been trivial to get into the box. Clarification from the OP might help.
  5. #15
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,107
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by petersonra View Post
    I don't know that I would put it into the "very dangerous" category. It isn't to code. Would not be real hard to make it code by just extending the EMT to the panelboard.
    simplest would have been to adapt to flexible conduit and drill the cover for the flex connector
  6. #16
    Join Date
    May 2014
    AZ
    Posts
    2,462
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    from a purely "wire science" view, funny looking wire layouts are not that risky. but as we all know, having a std is a better way, but even std's start to look like patch-work when you have US std, Can std, UK std, and the many other std's around the world.
  7. #17
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,467
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Someone on this site, once asked why we even needed inspectors. I said you would be surprised at the stuff I see when they know I'm coming out. Could you imagine what they would do if they thought no one was going to check on them?
    I can build anything you want if you draw a picture of it on the back of a big enough check.
    There's no substitute for hard work....but that doesn't mean I'm going to give up trying to find one.
    John Childress
    Electrical Inspector
    IAEI / CEI / C10
    Certified Electrical Inspector
  8. #18
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,408
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't think that litigant radishes or any other root vegetables threatening to sue should be fielding contractors.
  9. #19
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,325
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by FionaZuppa View Post
    That looks almost "workman-like" compared to some photos I've seen posted.
  10. #20
    Join Date
    Mar 2003
    New York
    Posts
    1,556
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would just take the cover off and feed straight to the breakers, saves wire, so money in the bank!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
