User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Linear LED Replacements are Junk - UC Davis Study
  1. #1
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,929
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    http://www.ecmweb.com/lighting-contr...ts-performance
    Roger Ramjet NoFixNoPay
  2. #2
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,704
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is it worth registering to be able to read it?
  3. #3
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,929
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MAC702 View Post
    If the topic interest you, registration is free.
  4. #4
    Join Date
    Dec 2010
    Posts
    1,448
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ramsy View Post
    And if it doesn't interest you they charge?
    The more they overthink the plumbing, the easier it is to stop up the drain
  5. #5
    Join Date
    Feb 2016
    Illinois
    Posts
    1,215
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dkidd View Post
    I always laugh when I see classified ads that say "Call xxx-xxxx if interested." I think to myself " What number do I call if I'm not interested."
  6. #6
    Join Date
    Oct 2007
    Piedmont region of NC
    Posts
    760
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Great stuff ramsy. It looks like linear LEDs that run on only their designed driver compare to linear fluorescents.
    https://cltc.ucdavis.edu/sites/defau...02017-11-1.pdf
    Ravenvalor
    Electrical Contractor
    Piedmont Region of NC
    "Good day and good premises." (Ayn Rand)
  7. #7
    Join Date
    Oct 2007
    Posts
    760
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You don't have to register to read the study and there is a link to it in the article. Here is the link to the study.
    The study says that linear LED lamps are not as bright as linear fluorescent. They tested the 4' T8.
    There was one exception where LED out performed fluorescent though. In a wrap around fixture the trapped heat reduces the lumens of the fluorescent thus making it less brighter than the LED but only in the type of LED that has a separate driver and not integral with the lamp. It does not necessarily have to be a lamp that fits into a socket I believe. I imagine it can be some sort of a strip or a lamp that connects to a driver in the fixture. (Note: driver and not fluorescent ballast). Furthermore they say the driver has to be specifically designed for and listed for the lamp and vice versa.
    I have been looking for this type of system and cannot find it. Does anyone know where I may find a well made system like this?
    Thanks,
    Ravenvalor
  8. #8
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,054
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sort of an aside. I have 4 foot fluorescent fixtures in my garage. They don't work real well when it is -13 like it was this morning.
    Is there a better option? Like an LED replacement?
    Bob
  9. #9
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,499
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    189194-2156 EST
    petersonra:
    Thr LED chip itself will work well at low temperatures. Funtion will be driver dependent. But quality LED fixtures should be good. Look at their temperature specifications.
    Fluorescent bulbs use a gas(s) plus mercury to generate UV to excite the phosphors. This mixture is quite sensitive relative to temperature, for electrical characteristics, and UV emission.
    I switched to LEDs ouside in place of CFLs and results have been good.
    There are problems with some LEDs on quality and RFI noise.
  10. #10
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,957
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    One interesting point that I had not previously given enough attention to is the more strictly downward direction of light from the LED tubes.
    I had seen it as a potential efficiency boost because the diffuse reflection from the backing surface of the luminaire caused a wastage of some light.
    What I had not considered was the balancing advantage of the distributed light source of the reflector makes for a less glaring light source with less of a point light source and therefore less harsh shadowing. For some work environments that is a big factor.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
