User Tag List
Results 1 to 5 of 5
Thread: Listed connector for bare copper #6 awg
  1. #1
    Join Date
    Dec 2013
    Weymouth, MA USA
    Posts
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there a connector available that is listed for bare copper #6 and/or #4 awg grounding wire? We've used 1/2" black plastic button connectors in the past, but they only list Romex in the spec sheets. It would be used for the water pipe ground coming into the panel.
    Sent from my SM-G930P using Tapatalk
  2. #2
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,950
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, there is a listed connector. It is called a “kenny clamp”.
    But there is no code section that says you have to use a connector at all.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #3
    Join Date
    Feb 2003
    Fl
    Posts
    17,470
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As Derek points out, a connector is not required by the NEC.
    Roger
    Join Date
    Dec 2013
    Weymouth, MA USA
    Posts
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wow!! Thank you!! That was bugging me, haha
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,595
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Other companies besides Kenny make fittings for this purpose. Bridgeport makes some nice ones too:
    http://www.bptfittings.com/Home/Prod...00781747944450
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
