Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: Fuses vs Circuit breakers in switch gear
  1. #41
    Join Date
    Jan 2008
    Posts
    8,863
    Quote Originally Posted by mbrooke View Post
    I honestly do not know
    Though I doubt I will exceed 10,000amps.
    Current limiting fuses are often used to reduce risk of transformer rupture for faults closer to the substation.
    I have never used them on outdoor MV for arc flash reduction but I suppose you could if you found a benefit.
    BB+/BB=?
  2. #42
    Join Date
    Jan 2011
    United States
    Posts
    6,897
    Quote Originally Posted by mivey View Post
    None that I know of but I think about it with lightly loaded transformers and higher voltages.
    At what voltage does it become a concern?
    What is esoteric knowledge today will be common knowledge tomorrow.
  3. #43
    Join Date
    Jan 2011
    United States
    Posts
    6,897
    Seen some POCOs add CLF on pole pigs near the sub- that would make sense.
  4. #44
    Join Date
    Jan 2008
    Posts
    8,863
    I don't really worry about systems below at 12 kV and below although it is possible.
    BB+/BB=?
  5. #45
    Join Date
    Jan 2011
    United States
    Posts
    6,897
    What would you say about 25kv or maybe even 34.5kv? Also can a modified saturation curve prevent it?
  6. #46
    Join Date
    Jan 2008
    Posts
    8,863
    The smaller the transformer the greater the risk but usually starting around 4kA to 6kA of fault can be a concern target.
    BB+/BB=?
  7. #47
    Join Date
    Jan 2008
    Posts
    8,863
    I would check for favorable conditions, especially on a 34.5kV system.
    Don't know about the sat curve, would have to check.
    BB+/BB=?
  8. #48
    Join Date
    Jan 2011
    United States
    Posts
    6,897
    Did not know this- much thanks. Up to 10ka I will just spec a K or T link... I never gave this much thought.
    Thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
