Results 1 to 5 of 5
Thread: LV Test
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    1,796
    LV Test
    Can anyone shed some led on the what’s involved do this cat6 testing? Need 2 men I assume. Thanks.
    Attached Images Attached Images
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,039
    Quote Originally Posted by mstrlucky74 View Post
    Well, first of all, the procedure they handed you is typical cut-and-paste crap. The Fluke instrument they want you to use went out of production in 2005, and the ITC-IV meter is for copper only, not fiber. I wish you good luck.
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    1,796
    here is a little mote info
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	19269   Click image for larger version.
  4. #4
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,039
    Sorry, that is too low a definition to read.
  5. #5
    Join Date
    Jan 2014
    chicago, il, USA
    Posts
    353
    You can rent testers. I use the Fluke DTX1800 there is also the newer DSX5000. They cost about $20,000 new. You are looking for something that will certify the cable to EIA/TIA standards and produce a report that you can submit to the client. These both have optional modules for testing fiber as well. If you have never done fiber work you might want to hire someone to do it.
    One other thing, The omniscanner 2 is no longer supported. You won't be able to get one that has current calibration, This would render it about as useful as a dirty rock for cable certification.
    The world is round, you will get there no matter what path you take.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
