Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: USB memory sticks
  1. #11
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,285
    Some thumb drives contain a small read-only partition which contains optional encryption software to be used in securing data on the drive. If that is the first partition, the less flexible HMI bios may not recognize the data partition in second place in the partition table.
  2. #12
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,709
    Quote Originally Posted by GoldDigger View Post
    That's getting above my pay scale. How do I check for that? Then again for the $s, I'll just buy a different brand.
    Tom
    TBLO
  3. #13
    Join Date
    Jul 2006
    Roughly 5346 miles from Earls Court
    Posts
    2,602
    Quote Originally Posted by ptonsparky View Post
    I use the windoze disk manager (Administrative tools -> Computer Management, click on "Disk Management"), for each physical drive, you should see a pictorial layout. OTOH, getting rid of them is usually a command-line operation, so you probably don't want to go there. (A different stick is much easier, if it works.)
  4. #14
    Join Date
    Dec 2012
    Posts
    19,285
    When you stick it into your computer, does it show you just the "hard drive" or does it show you a drive and a CD (read-only) device?
  5. #15
    Join Date
    Jun 2003
    Posts
    9,709
    Nothing read only.
    A newer model HMI recognizes the Lexars and while the older HMI may not use more than 4G, it does tell me the capacity of the 16G Kingston. Go figure.
    Tom
    TBLO
  6. #16
    Join Date
    Sep 2014
    Nashville, TN
    Posts
    140
    This is from memory, which makes it automatically suspect, but I think it has to do with sector size.
    IE: Old hard-drives (less capacity, ergo smaller sector size) will not be (are not being) recognized by newer operating systems.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
