User Tag List
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 42 of 42
Thread: Holes in steel studs
  1. #41
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,704
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Strathead View Post
    If no one hears it, did you really drill the hole?
    The punch is REALLY fast. Faster than a cough...
  2. #42
    Join Date
    Jun 2017
    Jupiter
    Posts
    27
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How big of a hole is actually being made? An electrical inspector usually will not question this practice, unless somebody appears to be "pushing the envelope." I had an older model Greenlee punch and I can tell you - this thing made holes that were WAY too big. One would literally have to nail plate the steel studs because the 1-1/4 clearance might not have been maintained.
    BTW - All I'm hearing is "load bearing" wall and nothing else matters. This is not true. Walls can be smoke partitions and not be load bearing. Walls can be fire-rated walls and not be load bearing, and will usually extend up to a roof deck. A "standard fire wall" more often than not is a non-load bearing wall, so don't be so quick to call the guy's boss!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
