User Tag List
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 42
Thread: Holes in steel studs
  1. #1
    Join Date
    Jan 2018
    Omaha Nebraska
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Our inspector is telling me that we cannot punch our own holes in the web of steel studs. I did a bunch of research online and he may be correct. The steel stud manufactures have parameters for holes sizes and where they can be made. Center of web no closer than 2' in addition to length and with dimension of the hole.
    1) Has anybody run into this before?
    2) Is there a repair for making additional holes? We really don't want to re run all the conduit.
    Thanks
  2. #2
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,961
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Punched literally a few thousand holes or more over the years.
    Got a link to where you got the specs?
    We drill out wooden studs, so why would punching metal be any different?
    I have never really did more than use the same basic rules for both.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #3
    Join Date
    Feb 2003
    Pennsylvania
    Posts
    2,495
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The IBC addresses this as well as other building codes i would suspect. load bearing non load bearing and so on.
  4. #4
    Join Date
    Jan 2018
    Omaha Nebraska
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    See attached. I checked the IBC and Steel Stud Manufactures Association. Both say additional holes have to be approved. Our inspector wants a document that allows us to make additional holes.
    Attached Images Attached Images
  5. #5
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,957
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by phisher View Post
    Check the documentation from the manufacturer of your particular steel studs. They are the only ones that can provide such a document since IBC and the industry association are silent.
  6. #6
    Join Date
    Apr 2003
    Planet macmikeman
    Posts
    3,488
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I sometimes wonder if any of you guys are able to get anything accomplished at all.
    85deg. an Sunny today.
  7. #7
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,126
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Such construction has no structural value for the most part, it is simply a partition, though it can have a fire rating, but that mostly depends on what you cover it with. The studs have little strength even as a partition until drywall is attached.
  8. #8
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,704
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ... additional holes have to be approved...
    They are approved, by the company that made my stud punch.
  9. #9
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,880
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Thanks
    That is ridiculous unless these are load bearing studs there is no reason not to make holes where needed. I would not waste any time with this guy. Everybody has a boss, find his and find out if this policy is really being enforced everywhere in your area.
    If you don't think too good, don't think too much.
  10. #10
    Join Date
    Feb 2003
    Pennsylvania
    Posts
    2,495
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    understanding your point.
    there are different Gage steel studs, i have seen steel with a mechanical room above them, in a recent dollar bottom, all the the mechanical equipment including a MCC making the studs load bearing
Posting Permissions
  • You may not post replies
  • You may not edit your posts
