Results 1 to 2 of 2
Thread: Code Clarification 310.15 (B) (5) (a) Neutral Conductor
  1. #1
    Join Date
    Jan 2009
    Posts
    20
    (5) Neutral Conductor.
    (a) A neutral conductor that carries only the unbalanced
    current from other conductors of the same circuit shall not be
    required to be counted when applying the provisions of
    310.15(B)(3)(a).
    My question is basically when is it called the “SAME CIRCUIT”
    Is this only relevant when it's connected to any single device? i.e. a Panel, ac, appliance?
    Or is it also at any multi wire branch circuit?
    In other words what is the definition of “SAME CIRCUIT”
    This came up at a code refreshing course last night, and it went back and forth
    I would appreciate your input on this
    Thanks all
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,764
    duplicate
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
