User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Arc flash PPE while not working
  1. #11
    Join Date
    Jul 2006
    Posts
    8,387
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here's a test video of MV Arc Resistant switchgear showing how it redirects the blast pressure.
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  2. #12
    Join Date
    Jan 2018
    Midland, TX, USA
    Posts
    5
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Company PPE Policy and "Non-Interaction"
    I do AFRA on a lot of low kVA pump jack sites where pumpers and other personnel very regularly walk by disconnect and panels that are energized but are not working on them. In pretty much all these cases the company minimum PPE level is required but nothing additional. If anyone was planning on opening a panel to check/ change a fuse, etc., they would be required to gear up and get their 0 gloves and face shield.
    No doubt it certainly depends on the nature of the facility and the level of available fault current. Had a guy tell me one time that their janitorial staff was required to suit up to sweep the floor at some areas within their facility. Seems like overkill but with a random fault it might be a life saver.
    "Resistance is not futile....its voltage divided by current."
Posting Permissions
  • You may not post replies
  • You may not edit your posts
