User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
Thread: Electrician
  1. #1
    Join Date
    Apr 2009
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can you tag out a light switch to fix a lighting fixture in a room?
  2. #2
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,957
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by yucatan4 View Post
    You can "tag it out", I suppose, but what is missing is the "lock out" part of the Lock Out/Tag Out combination.
    Even if it was in my sight the whole time, I would not feel comfortable working on the fixture unless I could figure out a way to at least lock the switch against casual operation.
    If the work is covered by OSHA, no way!
  3. #3
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,335
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    GIYF; see here.
    Click image for larger version.
  4. #4
    Join Date
    Dec 2012
    Posts
    19,957
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    GIYF; see here.
    Nice. And the locked cover covers the screws that attach it.
    No help for Decora or other odd style switches, and maybe a pain to attach as needed, but it does seem to satisfy the rules and be practical.
  5. #5
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    980
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Turning off the switch does not assure that the wires in the light-fixture box are off. It's likely that one will remain hot.
  6. #6
    Join Date
    Dec 2012
    Posts
    19,957
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by drcampbell View Post
    Such as when the switch is on a switch leg from a powered box.
  7. #7
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,961
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Or a constant hot for an EM fixture. Supposed to be an indicator but stuff happens...
    And fixtures can be raceways at times so....it’s a bit of fun at times opening wiring sections.
    "Electricity is really just organized lightning." George Carlin
    Derek
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,624
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    If the toggle switch is within sight how is this any different than a toggle switch being used as a disconnecting means for a piece of equipment?
    Rob
  9. #9
    Join Date
    Mar 2016
    Posts
    980
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Um, because it doesn't necessarily disconnect? (see above)
  10. #10
    Join Date
    Mar 2005
    Hampton, VA
    Posts
    353
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here is an OSHA interpretation letter on the subject.
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
