Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
Thread: Grounding temporary panels
  1. #11
    Join Date
    Feb 2003
    Illinois
    Posts
    23,623
    Quote Originally Posted by petersonra View Post
    I agree the equipment is not"structure" but the stand they build to mount in on certainly is.
    I see the support for the panel as part of the equipment. I think the change in 2017 was aimed straight at things like this.
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
  2. #12
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,350
    Quote Originally Posted by don_resqcapt19 View Post
    I agree, we're talking about a portable panel on a portable stand which is the support for the panel.
    Rob
  3. #13
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,200
    Quote Originally Posted by infinity View Post
    Yep and said equipment is only going to be used in a limited capacity and for a short duration.
    "Electricity is really just organized lightning." George Carlin
    Derek
  4. #14
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,671
    Is a feeder allowed to be fed from a receptacle? Just curious.
    I agree it is a structure. You are probably going to have to create a grounding electrode system for each one. It will probably need to be two ground rods 6 feet apart. The irreversible connection requirement is going to make it messy.
    What irreversible connection are you talking about?
    A panel, ground rod and GEC doesn't require irreversible connections.
    If you aim at nothing, you will hit it every time!
  5. #15
    Join Date
    Dec 2004
    Windsor, CO NEC: 2017
    Posts
    16,200
    Agreed. The one good that came from the change.
  6. #16
    Join Date
    Feb 2007
    N/E Indiana
    Posts
    195
    The change in definition would definitely be a bonus, however I am in one of those states that is still under the 2008 NEC. Since this is preliminary at this point for electrical demands, I am taking these comments to heart when reviewing the project. Have always appreciated the support from this site. Thank you.
  7. #17
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,098
    Isn't that what you have with a mobile home (where allowed) or RV plugged into a 50 amp 120/240 volt receptacle
    I would call a panel on a stand equipment not a structure. The 2017 NEC clarified what classifies as a structure.
    I agree.
    Another thing I have run into is at the small community hospitals that haven't shelled out the $$$$ for MRI equipment around these parts, there are companies that have MRI equipment in a semi-trailer. I have hooked up an outlet to plug these into - the one's I have been involved with were a 200 amp 5 wire pin and sleeve device and carrying 480/277 to that trailer. IIRC we only had 150 amp OCPD on it, still didn't look all that fun to be the truck driver and pull out that heavy cable assembly to plug it in when he arrives.
  8. #18
    Join Date
    Jan 2009
    Posts
    14,200
    Quote Originally Posted by kwired View Post
    It would depend on the duration that trailor was planted there for me.
    The ones around my old medical place were there for awhile, talking 6-18 months during remodel.
    If it 30 days or more, I would be putting in a GES in that case.
    a
    Derek
  9. #19
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,098
    Quote Originally Posted by jumper View Post
    a
    These are only there for a few hours and then leave. May be there a couple times a week or so.
    Used to be a mobile CT scanner that came around and used the same outlet, but most the hospitals now have their own CT equipment.
    I never been inside trailer to know what is in there, and hope I never am - that probably means I'm the patient.
  10. #20
    Join Date
    Jan 2009
    Posts
    14,200
    I have a vested interest. I am a patient.
    Derek
Posting Permissions
  • You may not post replies
  • You may not edit your posts
