Results 1 to 3 of 3
Thread: Manufacturer of this switch
  1. #1
    Join Date
    Mar 2013
    Rutland, VT, USA
    Posts
    342
    Hi,
    I am trying to identify at least the manufacturer of this fused switch. It is 5kV and no nameplates on it and I would like to find a manual on it. Does anybody have an suggestions? i thought it might be an S&C but in searches could not find anything that looked like this.
    Thank you in advance.
    Attached Images Attached Images
  2. #2
    Join Date
    Jul 2006
    Posts
    8,126
    The operating handle looks like those used by PowerCon, who not only makes their own metal enclosed interruptor switchgear, but also sells their switch mechanisms to a lot of other OEM gear mfrs.
    http://www.powerconcorp.com/docs/pc-016.pdf
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  3. #3
    Join Date
    Feb 2005
    Charlotte, NC
    Posts
    6,794
    Could be Powercon, ABB, or Siemens, they all use the same handle. The nameplate is located on the rear of the inside of the switch near the center phase contacts. Use a flashlight to look in that top window and you will see it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
