Why do you think I'm asking you to justify anything? You have nothing to do with it. I'm just stating the facts so that anybody who is interested can agree or disagree.
And if the Romex in conduit outside were failing and burning down houses we'd know about it too. Why are the hand wringers worried about NM in conduit and not service panels outside.The inside of the raceway rule was added because the hand wringers got all worked up about people running NM in a conduit across their front porch, it had nothing to do with the condition of the conduit in the real world.
If there were breakers failing outdoors and houses burning we'd know about it.
Why not do something about it? Like AFCIs, you can offer all kinds of arguments but their mind is made up.
-Hal
"Electricity is really just organized lightning." George Carlin
Derek
Ok, I see that. Didn't mean anything, I was too lazy to put it in my own words so I copy and pasted. Sorry 480.
-Hal
Yes, it would be. What about the cover makes it 'wrong': that it's not permanently constructed (as part of the exterior wall, like you mention), that it isn't sealed well, ???
If one used a proper weather-rated gutter under the panel, that would be fine too, yes?
NM coming in thru the back of the panel, while legal, is a more problematic install than it coming in thru the bottom like shown. At least with AC disconnects; every one I've seen with bad corrosion problems, the wire came in thru the back. Lack of/deteriorating caulking caused rainwater to get in and rust up everything.
The 'pop box' shown looks like siding (or were there when the siding was installed); there is a matching piece above the panel and one covering the drop above the meter
I am on the Right Coast, and have never seen nor heard of the afore-mentioned pop-box. We normally use the not-legal-but-allowed-anyway PVC conduit and LB method to bring cables from the crawl space into exterior panels.
Master ElectricianCode references based on 2005 NECLarry B. Fine
Electrical Contractor
Richmond, VA
My question is what keeps water from entering this thing in the first place?
As a homeowner I might be more concerned where that water goes if it does enter then I am about getting a little water on the outside sheath of NM cables.
If the thing is smaller then the panel and butted directly against panel that helps, but we get rain that travels nearly horizontal at times here.
Any condensation that does form within panel drains to within this space also.
Simple answer: never caulk the bottom edge/side of anything you attach to anything else.
Richmond, VA
Here we call "pop" "soda", so should I ask for a soda box? Oh yeah, we have basements so we don't need them.
You may well be the sharpest tool in the box, but in the end you are still a tool.
Bookmarks
