Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 72
Thread: Running RMC, techniques
  1. #21
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    3,532
    Quote Originally Posted by hbiss View Post
    HD, Lowes and many hardware stores have threaders if they sell pipe. I've gone that route when I had one or two ends. Just bring your pipe and throw them a few bucks.
    -Hal
    I tried that once, big orange, and they said they couldnt thread RGS because it messed up their dies. I think they were full of it. If anything, RGS may be softer alloy than "pipe" to facilitate bending (thats what I heard, maybe that is BS too).
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  2. #22
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,503
    Quote Originally Posted by MAC702 View Post
    They do threading at these stores, but it's done in the plumbing section, and you probably have no choice but to get tapered threads.
    Why would that be a problem?
    Cheers and Stay Safe,
    Marky the Sparky
  3. #23
    Join Date
    Mar 2008
    Posts
    9,503
    Quote Originally Posted by electrofelon View Post
    Plumbers use the same dies as we do. NPT.
    Marky the Sparky
  4. #24
    Join Date
    Feb 2016
    Illinois
    Posts
    620
    Quote Originally Posted by K8MHZ View Post
    Yep - Ridgid sells the same equipment to plumbers and electricians.
  5. #25
    Join Date
    May 2013
    Massachusetts
    Posts
    2,294
    Quote Originally Posted by infinity View Post
    Since you won't be cutting and threading the RMC you can use either threadless connectors or couplings.
    Most threadless fittings for RMC, are not formally rated for wet locations. The few that are, are hard to find. Most applications where I'd be running RMC, would be in wet locations.
  6. #26
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,094
    ... tapered threads.
    After a little research, it turns out our conduit is also tapered threads. It's our fittings that are straight threads. Shows you how much RMC I've run.
  7. #27
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,337
    That was me. I'd be embarrassed to say how many times I had to do it because my bender wasn't on the job with me, but hey, I was headed to the store for pipe anyway. Small jobs, too, so bend location wasn't critical or I had the measurement with me. Heck, most of the time I remembered to bring my tape measure with me into the store. Guess what I did if I forgot?
    I have used tape measures from store shelf many times, then put them back. Tapered threads is about all you will find on field threaded pipe. Straight thread never tightens it just "bottoms out".
    IMC is what is harder on threaders. If you have a threader die that is questionable at all it will leave damaged threads on IMC but still threads RMC just fine.
  8. #28
    Join Date
    Dec 2016
    Royal City, WA
    Posts
    110
    The couplers that that come on galvanized or black iron pipe are known as “ merchant couplers”. Those couplers all have straight threads. It’s only the cast couplings that have tapered threads.
  9. #29
    Join Date
    Mar 2008
    Posts
    9,503
    Quote Originally Posted by Dzboyce View Post
    All the couplings for RMC I have seen have straight threads.
    Like this:
    Marky the Sparky
  10. #30
    Join Date
    Mar 2008
    Posts
    9,503
    Plumber's couplings have tapered threads.
    Marky the Sparky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
