User Tag List
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: Running RMC, techniques
  1. #1
    Join Date
    Jun 2006
    NoDak
    Posts
    362
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Looking at a job that looks like it would require running some RMC.
    I'm just a small one man operation so I don't own mechanical benders and threaders, etc, and can't justify buying the equipment just to do this job.
    I've priced out pre-made threaded 90's and 45's as well as 10' sticks, but got visualizing the route in my head and was thinking I'll probably need to cut/shorten a piece of the RMC along the route.
    Without a threader how would I join up this shorter piece?
    Is there a Union of some sort that can be used to accomplish this joint?
    This conduit would be for service conductors feeding the meter/Main.
    Thanks!
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,371
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Since you won't be cutting and threading the RMC you can use either threadless connectors or couplings.
    Rob
  3. #3
    Join Date
    Mar 2017
    Florida
    Posts
    96
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Yeah but that's cheating
  4. #4
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,851
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    use the compression fittings or find a threader to rent, if laying it out carefully and only need a piece or two threaded take those pieces to someone that can thread them.
    Harbor Freight has a 3/8-2 inch hand threader set for only $75. Might be worth it for just one job, probably won't last if you use it frequently.
    Small sizes you can bend with hand benders - use next larger EMT size bender for RMc/IMC. Be prepared for stubs to not come out to same accuracy as they do for EMT, but if you use firm foot pressure while bending they will still be consistant. 3/4 EMT bender - deduct 6 inches for a stub for your mark - I think mine I marked it - use 6-3/8 for bending (1/2") RMC. I do bend 1/2 and 3/4 with hand bender fairly often.
    I have up to 1" threader handle and dies that I bought at auction for maybe only $30 or so about 20 years ago. Rigid brand. Only replaced cutting dies on one of them since I have had it.
  5. #5
    Join Date
    Jun 2006
    NoDak
    Posts
    362
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Compression coupling.
    So it looks like an EMT compression fitting ? I'll have to check it out with the supply house.
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,851
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sw_ross View Post
    Same design but not same dimension - it is made to fit RMC/IMC.
    Probably easy to find in stock for 1/2 and 3/4 but not so much for 2 inch. Probably kind of pricey for 2 inch as well I would guess.
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,371
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    They also make set screw types. Above 2" many set screw EMT connectors and coupling are also listed for RMC because the outside diameter are roughly the same for both types of raceways.
    Rob
  8. #8
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,950
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also, some supply houses have demos and rentals. If it is only a a piece or two, you may get to use a threader or possibly they will thread for a small nominal fee. If you are a good customer, maybe nada. I have went this route in a pinch.
    "Electricity is really just organized lightning." George Carlin
    Derek
  9. #9
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,851
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jumper View Post
    Somebody recently mentioned going to HD or Lowes and getting a stick of EMT, grabbing a bender and making needed bends, putting bender back on shelf and proceeding to cashier to pay for bent piece of raceway.
  10. #10
    Join Date
    Jan 2009
    Posts
    15,950
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    Well, ya gotta admit it is quick thinking.
    How come I never smart enough to think stuff up like this?
    Derek
Posting Permissions
  • You may not post replies
  • You may not edit your posts
