Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Bolts for oil-filled transformer
  1. #1
    Join Date
    Sep 2013
    USA
    Posts
    46
    The oil-filled transformer has an upper section, which is bolted to a gasketed flange of the oil tank. Transformer has about 2-3 psi of nitrogen, which "helps" in some oil buildup around bolts/ nylon nuts. I realize that nothing is perfect in this world, but is there some remedy for it, like special bolts/nuts, etc?
  2. #2
    Join Date
    Jan 2016
    PA
    Posts
    5,075
    is it over filled?
    over heating?
    try evenly tightening the bolts a few lb-ft
    or a new gasket
    without a pic or oil loss qty hard to gauge if it is a problem
    The difference between genius and stupidity is that genius has its limits.
  3. #3
    Join Date
    Jul 2013
    Resting under the Major Oak UK
    Posts
    1,123
    The company I worked for before I retired made nylon coated nuts, bolts and washers for caustic environments.
    But as far as I can see there is no reason for the conservator to be insulated from the main tank so I’m confused as to what you’re trying to achieve.
    The reports of my death are greatly exaggerated.
  4. #4
    Join Date
    Sep 2013
    USA
    Posts
    46
    Quote Originally Posted by Ingenieur View Post
    is it over filled?
    over heating?
    or a new gasket
    Oil loss isn't a factor, rather a nuisance, like those droplets hanging on some bolts. Obviously the gasket is not as perfect as it suppose to be, and replacing it would come at price, and it's not guaranteed this would fix a problem.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	19370   Click image for larger version.
ID:	19371   Click image for larger version.
  5. #5
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,098
    You need to learn how to explain things.
    That's not a leak; it's a calibrated expansion relief fitting.
  6. #6
    Join Date
    Sep 2013
    USA
    Posts
    46
    Quote Originally Posted by MAC702 View Post
    lol "calibrated"? "relief fitting?" people maintaining these xformers never heard of those. Elaborate on those a bit more. There is a nitrogen relief valve on transformer, but the original question was about oil leaks.
  7. #7
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,098
    Quote Originally Posted by moonshineJ View Post
    I guess I needed a smilie with that? Did you pass on that answer?
  8. #8
    Join Date
    Sep 2013
    USA
    Posts
    46
    Two posts, 0 bits of information, keep going spamspamspam
  9. #9
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,098
  10. #10
    Join Date
    May 2014
    AZ
    Posts
    2,254
    it could just be improper torq on those bolts. apply proper torq spec and see if it tightens any. if not then it would suggest the seal has an issue in some way and oil is making its way to the threading and oozing to the outside.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
