User Tag List
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 44
Thread: Underground Mine Grounding
  1. #1
    Join Date
    Oct 2015
    Vancouver BC
    Posts
    44
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi all, is anyone here familiar with grounding for an underground mine? I'm pretty sure the standard procedure is have your ground grid on the surface and run ground conductors down the shaft... but I was wondering has anyone put rods or plates actually down in the mine?
    Thanks
  2. #2
    Join Date
    Jun 2016
    Virginia
    Posts
    26
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I do a good bit of work in a limestone mine. We once had to run power to a previously unused area. We had them use their bolt drill to drill holes in the rock. We then put in ground rods with the holes stuffed full with brass and copper shavings that another customer let us have. Most of the work just gets checked during their regular MSHA visits, but the area AHJ wanted to look at this one and passed it.
  3. #3
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,966
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yo Iggy! Calling you here!
    "Electricity is really just organized lightning." George Carlin
    Derek
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,728
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I didn't know rock was conductive.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #5
    Join Date
    Oct 2015
    Vancouver BC
    Posts
    44
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    Haha, yeah maybe that’s the answer right there. That being said, I have had some luck with boring holes in bedrock and using that ground enhancement material.
  6. #6
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,714
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jumper View Post
    This should be right up his alley!!!
  7. #7
    Join Date
    Jan 2009
    Posts
    15,966
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Cow View Post
    Tailor made.
    Derek
  8. #8
    Join Date
    Mar 2003
    Vermont
    Posts
    2,169
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    From what i understand MSHA is like OSHA on steroids....~RJ~
  9. #9
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,728
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    OSHA is Ordinary SHA, and MSHA is Mega SHA.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  10. #10
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,945
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by romex jockey View Post
    You'd be surprised what you can get away with electrically though. Rubber cords are the rule not the exception and they are strung out everywhere.
    If you don't think too good, don't think too much.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
