Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 14-3 to non -fan rated bedroom ceiling box?
  1. #11
    Join Date
    Jul 2007
    Iowegia
    Posts
    17,855
    The number of 'gangs' at the wall switch isn't relevant to the requirement. You can have a 1-gang, 2-gang, 3-gang, or 10-gang. The NEC doesn't care.
  2. #12
    Join Date
    Feb 2018
    Iowa
    Posts
    240
    Quote Originally Posted by macmikeman View Post
    I put in around 200-300 ceiling fans every year in new housing and remodels. Once a year I might , might use a two gan box for the ceiling fan, in a case where the owner demands two location switching for the light kit. Otherwise its a single gang box for a standard single pole switch and a handheld remote control, or a dual speed and fan light dimmer housed in a single yolk , sold by Hunter or Lutron. I'm glad that this thread showed up though , cause we just now finally adopted the 2014 NEC from our previous 2008 , and I went to the code change update class a good three years ago for the 14, and forgot all about that code change. Hopefully we will stick to the 14 for a ten year stretch as well.........
    Simple solution is require a Listed ceiling box for a paddle fan in bedrooms, Den, Great room/Living room, dinning room, recreational room, or any other habitable room where a paddle fan may be installed.
    Fan or just a ceiling light, the fan box is there. That would makes it idiot proof.
    Jim
  3. #13
    Join Date
    Nov 2007
    Livonia, Michigan
    Posts
    233
    When wiring bedrooms, I ALWAYS install a 2-gang box with 14-3 to a fan-rated ceiling box. That is standard procedure for me.
  4. #14
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,835
    Quote Originally Posted by Jamesco View Post
    No such thing; as soon as you think you've made something idiot-proof, along comes a new-and-improved idiot.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #15
    Join Date
    Jun 2007
    Fredericksburg, VA 21 Hours from Winged Horses with traffic
    Posts
    161
    Also, there is:
    Murphy's Second Corollary
    It is impossible to make anything foolproof because fools are so ingenious.
  6. #16
    Join Date
    Mar 2003
    New York
    Posts
    968
    To me this is the code overstepping, what if I want to only turn 1/2 the lights on in day time and the full load of the fixture at night or any other control I would like!
  7. #17
    Join Date
    Sep 2011
    woodbridge, ct. USA
    Posts
    1,093
    Quote Originally Posted by sameguy View Post
    Well you might be able to tell an inspector that, but then again how much more is a fan box going to cost.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
