User Tag List
Results 1 to 4 of 4
Thread: Cold Meters=condensation?
  1. #1
    Join Date
    Feb 2018
    US
    Posts
    5
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wondering how important it is to bring meters inside when it gets super cold 0F and below. Not so much concern about the electronics bugging out, but condensation inside that’s just enough to turn it into a hand grenade. Especially on 480v. Is this a concern? If it’s sealed can it still build condensation?
  2. #2
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    1,023
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bringing them indoors will make condensation worse. Cold air is dry air; warm air might contain a lot more moisture. Leaving it indoors overnight will let the warm, possibly-moist air diffuse into it.
    I'm not sure how much of a problem this is. Any moisture that does condense will be distilled water, a poor conductor. (if the inside of the meter's clean) And if left out in the cold 24/7, there won't be much moisture available.
  3. #3
    Join Date
    Jan 2008
    NC & IN
    Posts
    3,512
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use them indoors in the heat during the day. Then they sit in the truck where it gets in the teens all night. That's why I carry three. Mine are always freaking out. I turn them on they flash, flicker, make noises , etc... Perhaps it's because they are all the same brand, with non contact tester, too. Plus the batteries die really quick in the cold. But I can usually get one to work correctly.
    They all work fine when it's normal temperatures .
  4. #4
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,628
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by drcampbell View Post
    I agree, bringing them in just increases how much condensation will form. They are going to do that anyway when you bring them in to use them, but to store overnight, leave them in the truck, one less heat/cool cycle each day to add condensation to it. Many better quality meters are sealed well enough this isn't much of a problem anyway.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
