Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 64
Thread: Electric Theory
  1. #31
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,786
    Quote Originally Posted by myspark View Post
    Whenever there is energy, there is electron. An atom is composed of proton, neutron and electron. We are all surrounded by atoms. . . it is the basic building block of all matter.
    Separating the electron from the atom nucleus is what releases the energy. the process called fission. Since electron is negatively charged, applying electric current could cause separation of the electron from its nucleus thus converting that energy that is usable like operating our hair dryer or kitchen toaster. It also can become destructive like "The Fat Man".
    In the transformer pri/sec winding scenario, magnetism happens when electric current is applied. Magnetism in itself has no energy. . . it is a force.
    Magnetism within the transformer core, forces the electrons from the primary to the secondary windings through the strength of the magnetic field. As you strengthen the magnetic field the more electrons is pushed to the secondary winding.
    Magnetism is essential in controlling energy and converting one energy to another.
    Many elements have unstable conditions in outer electron shell which gives them both chemical and electrical properties that you don't find in elements with a stable outer electron shell. Simple loss of an electron(s) isn't fission. Fission would be splitting the entire atom including the nucleus, which is what is done with nuclear fission. When they split a uranium atom what is left is not uranium. When you have a loss or electrons in an element you still have same element it just is left with a positive charge and is looking to react with some other element that has a negative charge.
    Elements that are conductive simply have electrons that move more freely then elements that are not considered conductive. All elements will let electrons move if enough voltage is applied, but "insulators" take a lot more voltage before to get the electrons to move. When electrical current flows most do think the theory that particles (electrons) aren't actually moving through the conductor but rather they absorb energy and bump into an adjacent electrons in the adjacent atom - and it is that energy that flows through the conductor not the electrons. The electrons are just the part of the atom that absorb and then pass on that energy.
    I disagree on the transformer theory you mentioned. Yes magnetism occurs when current flows through the primary coil, but it doesn't push electrons from primary to secondary. Only energy is exchanged via magnetic forces between primary and secondary. That magnetism then "excites" the electrons in the secondary circuit and they then pass the energy on to adjacent atoms and thus current can then flow in the secondary circuit.
  2. #32
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    Negative. Fission is splitting the nucleus of an atom, like Uranium 238 or Plutonium 239, into smaller elements. In the process of becoming more stable, smaller elements, some free neutrons are released, which are either fast (unmoderated) or slow (moderated), which strike other atoms' nuclei, continuing the process. If the process is sustained, you have a nuclear reactor. If not, you have a bomb.
    The electrons have virtually nothing to do with that reaction.
  3. #33
    Join Date
    Jul 2006
    Posts
    7,742
    "Electricity is a little tweeting bird, chirping in a meadow..., it is a wreath of pretty flowers, that smell BAD..."
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  4. #34
    Join Date
    May 2014
    AZ
    Posts
    2,322
    it doesnt have to is the answer. it goes back to a place that can provide a home for the charge. look at how lightning works.
    3 plastic or metal discs in space, two are very positively charged, one is very negatively charged. the neg disc full of extra electrons will jump over to either of the other two pos discs depending on which one is closer to allow such to happen.
    and to boot, the electrons on the neg disc do not have to come from either of the two pos discs.
    however, in a generator with mag field cutting across loops of wire, its like a water pump circulating in the cooling system of your car. gets pushed one way, must return on the other side of the pump.
    Quote Originally Posted by K8MHZ View Post
    There are electrons in an atom nucleus?
    squeeze hard enough you'll get all sorts of stuff in the nucleus area
    in general, no.
  5. #35
    Join Date
    Jan 2016
    PA
    Posts
    5,495
    Kirchhoff's current law
    or a restatement of the theory of conservation of charge
    charge seeks equilibrium
    if current (charge/time) leaves a node the current entering and leaving must = 0
    think of a xfmr as a node
    now consider a system of grids
    each grid independent of the other (no Cu interconnects) but sharing the same earth reference (obviously)
    assume 2 adjacent grids (1 and 2) have L-G earth faults simultaneously
    the Grid 1 source is 'closer' to the Grid 2 fault, ie, lower Z rtn path than to its own source, Grid 2 source
    and vice versa
    will the fault current 'motivated' or generated by Grid 2, return to the 'closer' (lower Z rtn earth path) Grid 1 source?
    and vice versa, Grid 1 i fault rtn to Grid 2 soure?
    more likely to share: source 1 will get i from 1 and 2, the same for source 2?
    does the source care where the rtn equalization charge comes from?
    The difference between genius and stupidity is that genius has its limits.
  6. #36
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,256
    The only complication to that current flow calculation comes for the special case of a capacitor. A net positive charge builds up on one plate, balanced exactly by a net negative charge on the other plate. And a displacement of charge as dipoles within the dielectric line up with the resulting electric field.
    If you want to be able to assert that the total current through any cross section of the circuit will be identical you "fake" the calculation by defining "displacement current" which is a function of the dielectric constant and the rate of change of the electric field integrated over the cross section.
  7. #37
    Join Date
    Jan 2016
    PA
    Posts
    5,495
    for general engineering calcs that has no real bearing
    now f you are into high freq electronics or small order tc fault calcs it may
    but in general if you account for Xc (1/(jwC) in the calcs it is a non-issue
    especially once charged and looking at steady state values >5 tc
    on a quantum level, yes
    on a practical level, moot
  8. #38
    Join Date
    May 2017
    SCV Ca, USA
    Posts
    324
    Quote Originally Posted by kwired View Post
    You can disagree with anything that I said, but it doesn't make you right. This is social media.
    Anything that is said by members is either hypothesis or opinion. . .nothing is binding.
    Unlike testifying under oath or audience, with authority, like a group of scientists known for their work, anyone should take someone's word with a grain of salt.
    Social media is exactly what this site is. Readers can either take it or leave it. If they find it beneficial then more power to them.
    All these things are for entertainment purposes...and to say that you are an authority of a subject matter will only put you in a position where if someone gets hurt or dies because of what you said, you should be prepared to answer and stand by your word. Someone forced to answer has happened before.
    If you don't believe me which is likely because of what you've said earlier, check with an attorney specializing in "The Internet Law".
    We live in a litigious society. . .and no one seem to take responsibility for their action. People always try hard to find someone else to blame.
    I have said what I needed to say regarding the topic.
    Thank you for listening.
  9. #39
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,850
    Quote Originally Posted by jaymiller View Post
    Why does electricity go back to its source?
    Happy that you asked yet?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  10. #40
    Join Date
    May 2013
    Massachusetts
    Posts
    2,312
    You cannot really know exactly where any electron is, within the atom. All that we really see in diagrams of the atom, are probability clouds of where the electron is statistically likely to be. The miniature "solar system" model of the atom is oversimplified.
    On rare occasion, the electron could be inside the nucleus, but in general, it isn't. Energy would have to be destroyed for the atom to simply collapse and have the electron coalesce with the nucleus. The electron probability clouds are what give the atom its size. Atoms are so empty that if it were scaled to a stadium, the nucleus would be the size of a marble. All that space is maintained by the electric fields associated with the electrons, as they surround the nucleus.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
