Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Junction Box Location
  1. #21
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    Quote Originally Posted by jap View Post
    It's not that big a deal.
    If done correctly the splice will last as long as the permanent wiring.
    If not, then they call me.
    JAP>
    It's not so much that the splice will fail so much as you may need to add something to that circuit like this weekend when I had to add a closet light on to an existing lighting circuit. Digging through 24 inch of blown-in insulation to find that junction box was none too fun, although it would'nt have been much better had there been 50 tags in the Attic saying "J box below". So I see your point, I guess it's just me that hates blown in insulation LOL.
    Electricians do it until it Hertz!
  2. #22
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,786
    When I first started in this trade the guy I worked with seemed to like to put a lot of j boxes in attics, even on new construction. I think the idea was that we might use less copper, eliminate the need to run multiple cables down to switches, receptacles etc in many cases and maybe even get by with smaller volume outlet/switch boxes. But I don't know that we really saved that much considering we had additional boxes in the attic plus the time to make them all up. I got away from that practice to some extent even when I still worked for that same person and became journeyman and was making more on the job decisions myself. Now I hardly ever put a junction box in an attic on new construction. Existing construction can still be pretty convenient to use them at times though.
    Still a lot of places out there that had existing junction boxes and then someone came in and covered them with insulation though.
  3. #23
    Join Date
    Jan 2007
    Posts
    3,525
    Quote Originally Posted by JFletcher View Post
    Find what junction box?
    Evidently you knew there was a junction box already in the attic or you wouldn't have been digging around looking for it to begin with.
    If you're talking about not being able to find an existing ceiling fixture box that you can see from below when you're in the attic, then, that is a problem.
    JAP>
  4. #24
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    I knew that the recessed can light 3 ft to the left of where they wanted the closet light had a junction box mounted to it. However, if I was looking for just some random junction box mounted below 2 ft of blown insulation I never find it unless there was ceiling tags indicating its location
Posting Permissions
  • You may not post replies
  • You may not edit your posts
