User Tag List
Results 1 to 7 of 7
Thread: NAC & IDC ckts
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    NAC & IDC ckts
    Can they be in the same conduit per code? Thanks
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    To generate more responses you need to specify what NAC and IDC mean.
    Rob
  3. #3
    Join Date
    Mar 2010
    Lake of the Ozarks
    Posts
    1,048
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    They can. Some IDC ckts are noisy and can induce sound on the nac. Clicking and very low chirping. Most common nuisance noise would be on a speaker ckt though so not too much concern if just horn/strobes.
    1N73LL1G3NC3 15 7H3 4BILI7Y 70 4D4P7 70 CH4NG3.
  4. #4
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    (NAC)Notification devices e.g. strobes, speaker/strobes- (IDC)Initiating devices e.g. pull stations, smokes etc.
  5. #5
    Join Date
    Aug 2009
    Cypress, CA
    Posts
    61
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There isn't anything in the code that says they have to be separate. Your limitation will be per manufacturer, some required shielded wire if they are run together, due to noise as mentioned above.
    Check with the wire requirements for the specific FACP you will be using.
  6. #6
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,538
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ryant35 View Post
    ^^^^What he said.
  7. #7
    Join Date
    Feb 2018
    US
    Posts
    27
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, the code doesn't require them to be separate and can be run together. Your annunciator and LOC might be a different story.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
