Results 1 to 3 of 3
Thread: 750VDC sheilding
  1. #1
    Join Date
    Feb 2018
    Parker, CO, USA
    Posts
    1
    750VDC sheilding
    Hello, first time here. I am trying to find a suitable material for clear shielding to be mounted on GPO3 for arc shielding to isolate 750VDC. I am not finding very much information on required ratings for such applications. Does anyone know if there is a clear plexiglass or other material that is rated for arc blast?
  2. #2
    Join Date
    Jul 2006
    Posts
    7,810
    Quote Originally Posted by wareisjoey View Post
    Welcome to the forum.
    Depends on the size. There are plenty of Lexan / plexiglass / PMMA viewing window options available on 600VAC Arc Resistant switchgear and MCCs and if you think about it, that's roughly equivalent to 850VDC. But the size of the window is generally limited to 12" x 24" I think.
    PS:
    I just looked up "GP03" and see that it's glastic, so I'm not as sure about that. The windows I've seen are internally mounted on steel doors.
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  3. #3
    Join Date
    Aug 2004
    Northern illinois
    Posts
    16,801
    You will find no material "rated for arc blast". You would need to build something and submit it to UL and have them test it at the level of arc blast you want to claim it will protect against.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
