User Tag List
Results 1 to 2 of 2
Thread: Adding Heating Element to Aqueous Parts Washer
  1. #1
    Join Date
    Feb 2018
    Fayetteville, GA, USA
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would like to add a heating element to a metal parts washer for automotive use. The parts washer is a metal cabinet on legs that will carry 24 gallons of an aqueous washing solution. The washing solution works more efficiently if heated to 120 degrees Fahrenheit. This would be a 120v circuit preferably coming from a GFCI outlet. The circuitry would be similiar to a hot water heater.
    My question is should the actual metal washer itself have an electrical ground fault circuit installed leading from the washer back to the ground on the receptacle or does the GFCI itself prevent risk of electrocution?
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    17,563
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    The forum rules do not allow us to assist DIYers so I must close this thread.
    Read Before Posting: Forum Rules / Treatment of New Members
    This site is designed for:
    • Contractors
    • Electricians
    • Engineers
    • Inspectors
    • Instructors
    • Other electrically related individuals
    * This NEC´┐Ż Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
    Roger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
