Results 1 to 10 of 10
Thread: Do LED lights degrade over time
  1. #1
    Join Date
    Feb 2007
    N/E Indiana
    Posts
    195
    Does the lumen output of an LED bulb degrade over time. It appears that bulbs that were installed 2 years ago do not have the light output that I remember when installed. Since these are in corridors and stairway, my concern is adequate light levels for code compliance. Will obtain light meter to check, but wondered about bulbs getting "dimmer" over time.
  2. #2
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    6,889
    180221-1545 EST
    Yes.
  3. #3
    Join Date
    Apr 2006
    Springfield, MA, USA
    Posts
    3,158
    Yes, in particular high temperatures cause LEDs to decay, and one way that manufacturers save money is to use fewer LEDs, driven harder to produce a given light output. This makes the LEDs hotter and causes them to decay faster.
    There are other degradation mechanisms; these are seen with many phosphor based lights (LED, fluorescent, etc)
    -Jon
  4. #4
    Join Date
    Jul 2015
    Soldotna, AK, USA
    Posts
    124
    If they all really lasted 10 years we and the manufacturer would be out of the job pretty quick. Have seen a lot of LED failures, all different makes and styles.
  5. #5
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,807
    As determined under the LM-80 standard, Manufactures are not required to list LED Lumen Maintenance on the nameplate.
    Roger Ramjet NoFixNoPay
  6. #6
    Join Date
    Feb 2012
    United States
    Posts
    605
    Yes they have a useful Life of only 50,000 hours. keep your receipt. I have a couple floods bought 10 yrs ago with same output.
    Sent from my SM-G900V using Tapatalk
  7. #7
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,285
    Quote Originally Posted by mike_kilroy View Post
    About seven years ago I bought some low watt bulbs (upper end of night light brightness) and some floods from the same manufacturer at Costco.
    After about three months of constant use the small bulbs were getting seriously dimmer. Costco ended up recalling both types.
  8. #8
    Join Date
    Mar 2018
    US
    Posts
    2
    Yes, it will.
  9. #9
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,585
    Quote Originally Posted by 102 Inspector View Post
    yeah, they burn down, not out.
    some luminaries are able to compensate for this.
    the fixture is underdriven to start, and as it ages,
    there is capacity for it to increase power to the led's
    to maintain the same light output over its rated life.
    don't expect this on any lower end LED luminare.
    this also means, if you think about it, that the device
    becomes less efficient over time. sort of like a prius.
    as the batteries lose their spunk, the engine runs more
    and more in the course of operation.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  10. #10
    Join Date
    Apr 2018
    Minneapolis´╝îMinnesota´╝îU.S.
    Posts
    5
    Yeah, structural design process, power adapter and lamp mismatch, bad heat dissipation ,heat dissipation of lamps and lanterns themselves, transmittance of glass or covers and so on, all these factors will influence the lumen output of an LED bulb.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
