User Tag List
Results 1 to 5 of 5
Thread: EMT Ground Hub??
  1. #1
    Join Date
    Mar 2007
    MidWest
    Posts
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    EMT Ground Hub??
    So I have never seen this and no luck finding it…when using EMT as a raceway for mechanical protection of a supplemental bonding conductor for ex. ½”C with a #6AWG ground I was looking to see if I could find a ground hub / choke to be used at each end of the conduit however everything I have found [oz/gedney, etc.] the hubs are threaded. Is it possible, common acceptable [UL?] to thread EMT, I could not find a similar product with set screw type connection? Any assistance is appreciated…
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    17,558
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Just use EMT connectors and then the hubs.
    Roger
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,990
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mike01 View Post
    You cannot thread EMT. You can do what Roger suggested but threading the connector into the hub is a technical violation. Like Roger for me it isn't a problem.
    Rob
  4. #4
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,071
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm curious, is there a reason for you to not use a half inch bonding bushing on the threads of a set screw EMT connector?
    Another Al in Minnesota
  5. #5
    Join Date
    Feb 2003
    Fl
    Posts
    17,558
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by al hildenbrand View Post
    The reason it was done in the photo was due the design engineer wanting more expensive components.
    Roger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
