User Tag List
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 71
Thread: Meter has rigid conduit to disconnect
  1. #1
    Join Date
    Feb 2018
    boston
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey Mike or forum, can you answer a quick question please? Theres Rigid pipe from meter to a disconnect. Rigid pipe can not be changed at this time. I know pvc is preferred method because of parallel paths. Would threading a PVC male end to Rigid pipe entering Disconnect be an acceptable solution?
  2. #2
    Join Date
    Feb 2007
    USA
    Posts
    5,847
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cduke103 View Post
    PVC is not necessarily a preferred method.
    In my area PVC is not usually used in this instance.
    must be a local not a NEC thing.
  3. #3
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,504
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here PVC is the "preferred" method if there are no hubs involved as metallic conduit would require a bonding bushing.
    The Code pretty much ignores the "parallel path" created by the metal nipple in this situation.
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  4. #4
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,482
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    To be precise, IIRC, in this instance the nec doesn't use the term "parallel path" it uses the term "objectionable current". Basically no one worries about this.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,130
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    As the others have stated this is not an issue and is an example of when objectionable current on the raceway is permitted by the NEC.
    Rob
  6. #6
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,175
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    I would say instead that since the NEC does not object to it, the current is per se not objectionable.
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,130
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    LOL.
    Rob
  8. #8
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,979
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I call it the unavoidable objectionable.
    If you don't think too good, don't think too much.
  9. #9
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,577
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Since everything (conductive) on supply side of service disconnect is required to be bonded to the grounded conductor - there isn't much avoiding parallel grounded conductor current on those items if there is conductive materials between them. NEC must not think this is objectionable or they would have different requirements. They are a little more strict on bonding of service raceways then non service raceways though, which is a good thing I think if you are going to have some parallel current in the raceway.
  10. #10
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,130
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    There are many parallel paths in the line side of the service disconnect. In a building with multiple services there are parallel paths on the GEC's, metal raceways, etc.
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
