Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Ham radio & LED
  1. #1
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,952
    Ham radio & LED
    We left a sample LED retrofit for a recessed can with a customer. He is a HAM radio operator and mentioned that he had heard they may mess with his system. Any thoughts?
    One lamp didn't seem to bother at the moment.
    Tom
    TBLO
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,030
    Quote Originally Posted by ptonsparky View Post
    LED's are RFI-rich, but I don't know that it's any worse that CFL's or standard fluorescents.
  3. #3
    Join Date
    Jun 2003
    Posts
    6,898
    I think that depends a lot on the lamp/fixture and the design of the driver. If they do a good job of filtering the input current, a can light or a simple replacement lamp shouldn't radiate too much noise.
    If they let the harmonics through to the branch circuit wiring, the longer wire lengths can act like an antenna, and radiate some noise.
    Also, I could see how a 4' fixture might have enough wiring length inside the fixture to radiate some noise from the wires feeding the LEDS.
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    23,362
    I wonder if he can light up the LEDs when he transmits?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #5
    Join Date
    Jun 2003
    Posts
    9,952
    Quote Originally Posted by LarryFine View Post
    I’ll ask him!
    Tom
    TBLO
  6. #6
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    10,028
    Some LED's do produce RFI in the amateur radio bands, others do not. It's not the LED's that make the noise, it's the power supply circuitry in the base. Your customer was wise to check the lights before you installed them.
    Cheers and Stay Safe,
    Marky the Sparky
  7. #7
    Join Date
    Mar 2008
    Posts
    10,028
    If that happens, he has 'RF in the shack' and remedies abound to correct that. I will hazard to guess the answer is no. Ham radio operators want as much of their signal to make it all the way to the antenna and not be radiated by the feed line into the radio room.
    Marky the Sparky
  8. #8
    Join Date
    Mar 2003
    Washington
    Posts
    14
    LED Interference
    I had to pull the LED bulbs out of both of my garage door openers. None of my remotes or Homelink transmitters would work with LED bulbs. Went back to fluorescents and no issues.
  9. #9
    Quote Originally Posted by K8MHZ View Post
    No LED's in my garage/ham shack, have a couple of noisy fluorescent ballasts, the worse noise is made by the charger for my Sears 9V cordless drill.
    73 de W4KAV
    Mt. Falls, Va.
    "Not a sermon, just a thought"
    A licensed electrically-related individual
  10. #10
    Join Date
    Feb 2003
    Illinois
    Posts
    23,732
    Quote Originally Posted by b1miller View Post
    The instructions for the last opener I installed in my garage covered that in the instructions. They said that use of LED lamps in the opener would likely interfere with the correct operation of the remotes.
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
