Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: gas fireplace not igniting
  1. #21
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,547
    Quote Originally Posted by GoRaWa1 View Post
    I write this to (hopefully) add a little bit of information. I am a retired Mechanical Engineer and not an Electrician or Plumber). Our fireplace had the same intermittent problem. The fireplace has a standing (lit all of the time) pilot. The flame from the pilot light heats a thermocouple that provides millivolt power to the switch on the wall. Of course, this millivolt power opens the gas valve when the switch closes. I recently learned are while this switch LOOKS like a $4.00 rectangular decora switch it actually should be a more costly $20 millivolt switch probably with less resistance. Skytech sells this millivolt switch, a timer switch, or a remotely controlled switch for this application. Now, to be perfectly honest, i bought the special millivolt timer and the measured resistance across its internal switch but it didn't seem much different than a regular $4.00 decora switch. Still, I can imagine the Skytech switch has a genuine purpose beyond my understanding. While installing the timer, I decided to lightly sand the 15-year accumulation of residue (carbon?) off of the thermocouple. Since I replaced the switch and cleaned t
    he thermocouple, the fireplace always starts. I suspect that my repair had more to do with cleaning the thermocouple off than changing the switch. Most repair guys (as noted by a previous writer) would replace the thermocouple (which is reasonable). This is is more of an a/c or fireplace repair guy's area of expertise than an electrician's.
    That millivolt rated switch probably has different contact material and/or has a "wiping" action to help ensure a low resistance connection is made. Though the cheaper general use switch has a low resistance now, it may not keep as low of a resistance over time compared to one designed for millivolt operation.
  2. #22
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,365
    Quote Originally Posted by kwired View Post
    A millivolt circuit will, naturally, have both a low voltage and a correspondingly low current. It is much more sensitive to circuit resistance than a control or power voltage circuit.
    But, AFAIK, the biggest reason for a special switch is the have a contact design (wiping) and material (silver or gold) which will not develop a resistive or semiconducting surface corrosion layer that would break down when subjected to several volts or more but would block a millivolt circuit completely.
    Reed relays for low voltage applications typically use gold plated contacts even though that increases the likelihood of contacts welding/sticking on closure.
  3. #23
    Join Date
    Feb 2016
    Illinois
    Posts
    955
    I also have a standing pilot fireplace (Heat N Glow). When the thermocouple has issues, the pilot will not stay lit. I’d say your new switch fixed the problem!
  4. #24
    Join Date
    Dec 2012
    Posts
    19,365
    Quote Originally Posted by retirede View Post
    FWIW, my free standing propane heating stove has two metal elements in the pilot flame. One is a thermocouple for the pilot safety on the gas valve, the other, larger, one is a thermopile that runs the main burner valve through the millivolt thermostat.
  5. #25
    Join Date
    Jan 2011
    Posts
    2
    You are probably right...
    Could be. One thing I always try to do when I repair something is to avoid replacing two parts at the same time. As it is, having replaced the switch and cleaned the thermocouple, I have no idea which solved the problem.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
